zc turbo setups
Old Dec 21, 2002 | 06:51 PM
Speedfreak's Avatar
Default zc turbo setups
i know a couple people have zc turbo setups and i want to know somethings like
how much psi
t3/t4
bottom end built
blockgaurd
fmu
Old Dec 22, 2002 | 04:10 PM
PureCRXtasy's Avatar
New User
Default Re: zc turbo setups (Speedfreak)
how much psi
ZC's can hold 12 psi stock with GOOD engine management. I wouldn't go over 9 or so without a stand alone system.
t3/t4
The turbo you plan to run depends a lot on what you want to get out of it. Do you want a quick spooling street beast with little top end or do you want something with a little lag but serious upper RPM pull? There are probably 20 in between stages as well. What is your ultimate goal?
bottom end built
If you wanna boost over 12psi you'll need a built bottom end.
blockgaurd
Blockguard - good luck finding one for a zc
Block "posting" is a viable alternative though.
fmu
They'll work, but there are much better alternatives for the $$.
Old Dec 22, 2002 | 06:21 PM
quis23's Avatar
Default Re: zc turbo setups (PureCRXtasy)
aren't all d- series block guards the same? STR makes on for the d-series and i think it'll work for the zc.
97grnrs
Nov 28, 2006 11:52 AM
mrchris1979
Oct 17, 2005 01:39 AM
RustyRex
May 20, 2003 04:08 AM
OutLuDeD
Apr 17, 2003 10:31 AM
-=TWITCH=-
Mar 10, 2002 12:15 PM
