Installation tool...
Old Dec 26, 2002 | 12:21 AM
LJR-LUDE01's Avatar
Default Installation tool...
I'll be installing my kit soon and I want to see what has everybody use to install their kit... anything special... I want to be sure I have everything I would need so I don't have any set backs.... just list whatever you use thanks
Old Dec 26, 2002 | 01:18 AM
Flamenco-T's Avatar
Default Re: Installation tool... (LJR-LUDE01)
10, 12, 13, 17 mm wrenches and socket, low profile ratchet, electrical powered drill to with 3/8" drill bit to grind the block and drill mounting holes for IC, screwdrivers, jack, jack stands, small and large adjustable wrench to remove the stock oil pressure sender, or you can get a special tool I believe it's 26 or 28mm tool. If you have HKS SS BOV, you need a a pair of C-ring or C-clip pliers...
a lot of beers will help too....and a pack of cig
stan
Old Dec 26, 2002 | 05:03 AM
LJR-LUDE01's Avatar
Default Re: Installation tool... (Flamenco-T)
thanks stan... I got all that stuff except the c-clip pliers....
Old Dec 26, 2002 | 06:11 AM
evoeone's Avatar
i used your basic socket and wrenches, adjustable wrench, drill, hex bolts, and these damm vw's have those annoying torx screws,
mostly basic **** everyone has, but they always think they need more, and it should be a hell of a lot easier with a honda since the T and everything is in front, not like my **** thats hidden in ****** wonderland behind the engine its mostly bolt on/off **** the way i see it
good luck
Kwish
Classic Hondas
Jan 25, 2013 03:30 AM
justYncredible
May 1, 2012 05:56 PM
Bartman201
Jun 3, 2011 04:43 AM
Sivic90
Nov 27, 2008 04:38 PM
BadEH2
Aug 17, 2004 07:15 PM
