Digi 6+boost+timing retard?
Old Dec 25, 2002 | 09:55 AM
blufke's Avatar
Default Digi 6+boost+timing retard?
How do you set up the digital 6 to work when just boosting? What is a good setting for .45bar on a b18b? thanks for any input.
Old Dec 25, 2002 | 11:16 AM
rOby's Avatar
Default Re: Digi 6+boost+timing retard? (blufke)
im not sure if it was intended to retard via boost.
i know a btm would...
sorry im stupid
Old Dec 25, 2002 | 01:55 PM
blufke's Avatar
Default Re: Digi 6+boost+timing retard? (rOby)
anyone have a good idea on how to set it up? or is there just one way, and if there is lemme know what it is.
Old Dec 25, 2002 | 02:40 PM
safe driver's Avatar
the digi6+ has the retard activated when the pink wire gets power to it. so i would hook up the pink wire to the power feed on the digi6+ to keep a constent retard. this may work for the vafc hack because the hack tricks the ecu into not seeing the right amount of map vaccuum thus advancing the timing to compensate. so depending on much boost you'll run, you can set the retard to off-set the advancing caused by the negative value on the settings in the vafc.
did that make any sense?
Old Dec 25, 2002 | 02:44 PM
blufke's Avatar
Default Re: Digi 6+boost+timing retard? (safe driver)
not really. should have maybe added that i will be using the smc+ and no vafc.
Old Dec 25, 2002 | 02:57 PM
the digi6 won't increase the amount of retard in relations with the boost. the retard is constant. it either retards at a set value or it doesn't at all. so the best way to use the digi6 to retard is to make the retard function activated at all times.
this , in theory, could bring the ecu timing back to 0 depending on your tuning. or maybe even retard it more but i think the retard only goes up to 10 degrees.
so if the fuel is set to, for example -50%, the ecu will advance the timing because it thinks there is too much vaccuum. and if you set the retard on the digi6 to whatever value of retard, you can off-set the advancing by the ecu and bring it into retard.
hope that helps, i can't think of anyother way to explain it
[Modified by safe driver, 12:02 AM 12/26/2002]
Old Dec 25, 2002 | 03:29 PM
tony1's Avatar
You could use a pressure switch (hobbs switch) to activate the retard at a preset boost level. I don't know how smooth the transition would be though since it won't be retarded relative to boost level. It will retard the entire amount at the preset boost level. If you're running low boost you really don't even need timing retarded and if you're running high boost you should have a hondata or ems or something to control timing.
Old Dec 25, 2002 | 05:54 PM
PM-Performance's Avatar
Default Re: Digi 6+boost+timing retard? (tony1)
yea thje retard function worked great for my nitrous , but i was wondering too how it woould work with boost now >?
i prob wont even use it , i have a hondata, so will prob mess with the timing off that
Old Dec 26, 2002 | 06:10 AM
blufke's Avatar
Default Re: Digi 6+boost+timing retard? (itr206)
uppity....anyone else want to share on their use of the timing retard on the digi6, or if i should even use it.
Old Dec 26, 2002 | 07:11 AM
willyboyK20's Avatar
what would be the maximum of a low boost setting in your opinion?
Old Dec 26, 2002 | 07:38 AM
blufke's Avatar
Default Re: Digi 6+boost+timing retard? (willyboyD16)
im on a stock ls with fairly high miles so .45bar most of the time and maybe up to 8-9 but i dunno.
apohl23
Apr 19, 2009 02:17 PM
ajreid
Sep 9, 2005 08:39 AM
b18c1995
Nov 27, 2004 01:03 AM
m0t0rhead
Nov 5, 2003 05:16 PM
FUP23
Sep 17, 2002 04:44 PM
