Noticeable difference between .63 A/R stage 2 vs stage 3? (for an H22)
Hi guys,
I'm thinking about swapping out my T3 0.63 a/r stage 2 turbine for a stage 3 turbine. will there be a noticeable difference between the two stages?
IIRC the difference in stages is the diameter of the turbine and the opening right? BTW this is for an H22 which will be boosting at 7 PSI at first then eventually 10 PSI (daily) and 15 PSI (track) once it's been built.
TIA
TIA
Re: Noticeable difference between .63 A/R stage 2 vs stage 3? (BlueShadow)
youll definantly want the stage 3. If you have a big compressor wheel like a 60-1 i would even recommend a stage 5.
Re: Noticeable difference between .63 A/R stage 2 vs stage 3? (boosted3g)
Greyout
08-07-2003 08:15 AM
Greyout
07-03-2003 10:48 AM
Full-Race Geoff
11-18-2002 11:31 AM
