Pics of Apexi AX kit on B18B1
Old 12-21-2002, 03:03 PM
glagola1's Avatar
Default Pics of Apexi AX kit on B18B1
A few people have asked that I post some pics of my set up. Here you go:
glagola1 is offline
Old 12-21-2002, 03:31 PM
Honda4CX-T's Avatar
Default Re: Pics of Apexi AX kit on B18B1 (glagola1)
Nice "glagola1" ..... Just one thing I'd change is the Valve Cover (Moroso) .... or Paint it makes a BIG difference IMO ....
Other thn that it need nothing else
Honda4CX-T is offline
Old 12-21-2002, 03:38 PM
leadtrum's Avatar
wait so you kept the apexi manifold?
leadtrum is offline
Old 12-21-2002, 04:18 PM
Charles B.'s Avatar
Default Re: Pics of Apexi AX kit on B18B1 (leadtrum)
yep. people have also used the sohc greddy kit on their LS's. you just have to modifiy it slightly to fit. i personally like the APEXi kit better because of the ball-bearing turbo and optional water cooling section.
btw, nice setup
Charles B. is offline
Old 12-21-2002, 04:57 PM
Default Re: Pics of Apexi AX kit on B18B1 (SuperDuperEG)
Ball-Bearing Turbo
Broken Gearbox is offline
Old 12-21-2002, 07:26 PM
CzanSOHC's Avatar
Default Re: Pics of Apexi AX kit on B18B1 (dEF juNKie)
that is nice
CzanSOHC is offline
Old 12-21-2002, 07:31 PM
leadtrum's Avatar
btw, nice setup
gotta say the same to you man...makes me have hope for my little setup too.
leadtrum is offline
Old 12-21-2002, 07:35 PM
curiousgpnoy's Avatar
how much for the whole kit???
curiousgpnoy is offline
Old 12-21-2002, 07:48 PM
RodimusRhymes's Avatar
Default Re: Pics of Apexi AX kit on B18B1 (curiousgpnoy)
$2200... but thats without intercooler.
He isn't using the apexi intercooler. What intercooler is that bro
RodimusRhymes is offline
Old 12-21-2002, 07:50 PM
glagola1's Avatar
Thanks for the compliments people. I agree the valve cover is pretty nasty but maybe all that will change when the vtec head finds a home there. (maybe someday)
I don't really think that turbo is too small for that 1.8 motor. It's about the same size or a little bigger than an OEM kind of application. The spool is awsome and I haven't run out of efficiency at 10psi. I'm going to run 14 as soon as I can get a Hondata and new map sensor.
The kit can be had for about 2000 new. I don't know where but that's what I hear. Oh, and that's with out the intercooler.
glagola1 is offline
Old 12-21-2002, 09:31 PM
What fuel mangement are you currently using??
Old 12-22-2002, 05:35 AM
glagola1's Avatar
Well, right now I am using the Greddy blue box thingy and a 255lph pump with stock injectors. It runs really good but I can only boost to 6 psi. A couple days ago I was running some 450's and an SMC but the drivability was not worth the fun of running 10psi. On monday I hope to order a Hondata.
glagola1 is offline
Old 12-22-2002, 08:54 AM
ATgrills.com's Avatar
Did you have to port out that manifold and redrill the holes?
or is it a B series manifold?
Tyler
ATgrills.com is offline
Old 12-22-2002, 09:00 AM
glagola1's Avatar
Default Re: Pics of Apexi AX kit on B18B1 (ATgrills.com)
I ported and drilled. Yeehaw
glagola1 is offline
Old 12-22-2002, 12:15 PM
Hondata
Old 12-22-2002, 06:38 PM
MugenNSX's Avatar
Default Re: Pics of Apexi AX kit on B18B1 (s2kcord)
Glagola, is there any specs on that turbo? I want to see if there is a way to use a BB turbo such as that on a HKS B series manifold? What turbo choices do I have that would bolt on to the HKS B series manifold? TIA
MugenNSX is offline
Old 12-22-2002, 07:48 PM
glagola1's Avatar
Default Re: Pics of Apexi AX kit on B18B1 (HybridEF2)
Here's a tip. Do a search on posts created by me, "glagola1". I've answered a lot of these questions and you can find a dyno graph of this set up too.
Basically, I don't really know anything about the IHI turbo except I really like it. It has the same bolt pattern and port as the HKS manifold but there is a problem with the stud configuration. The apexi (IHI) turbo has is designed so that it holds the studs and the manifold is bolted to it. The HKS manifold is designed so that it holds the studs. It's like they are both male if you know what I mean.
The HKS manifold is a JDM T25 which is different from a USDM T25. I don't know how much different though. It was designed to use an HKS T25.
Supposedly, Apexi is coming out with a manifold that will bolt this turbo to the B-series heads. We'll see.
glagola1 is offline
Old 12-26-2002, 06:38 AM
Charlie Moua's Avatar
nice finally some pix.
for all of you out there i have been constantly asking "galgola1" for engine bay pix for the past week. Hheheheh
looks nice bro. keep us updated on how the hondata tunning goes.
Charlie Moua is offline
Turbo R
04-23-2003 12:05 PM
Dangydang
04-20-2003 03:18 AM
slowassR
03-14-2003 09:55 AM
upstatecrx
General Discussion and Debate
02-06-2003 04:35 PM
ej1civic
01-14-2003 01:32 PM
Quick Reply: Pics of Apexi AX kit on B18B1
  • Ask a Question
Question Title:
Description:
