Lightend flywheel with turbo.
Old Sep 13, 2006 | 01:06 PM
95dc2teg's Avatar
Default Lightend flywheel with turbo.
Is getting a lightened flywheel (for example 8.8lbs) a bad idea with a turbo integra gsr? or is 8.8lb over kill? I am going to replace the clutch and i wanna know if getting a lighter flywheel is worth it.
Old Sep 13, 2006 | 02:32 PM
95dc2teg's Avatar
Default Re: Lightend flywheel with turbo. (95dc2teg)
no one?
Old Sep 13, 2006 | 02:47 PM
Mugencrxsir1's Avatar
I'm running a 12lbs flywheel with no problems, but I do believe 8.8lbs is too light. But for force induction I would choose a middle weight flywheel, but i've seen 7 lbs flywheels work for a while with low horsepower(under 300hp).........
Old Sep 13, 2006 | 04:43 PM
platinum00's Avatar
search the archives man. many posts on this.
you will be fine. running 8.5lb here.
platinum.
Old Sep 13, 2006 | 04:54 PM
ekb18c's Avatar
Default Re: Lightend flywheel with turbo. (platinum00)
If you shift fast enough, yeah it's fine.
If you don't then go with a stock type r flywheel.
Old Sep 13, 2006 | 06:08 PM
Garage 808 Hatch's Avatar
8.8lb here, 463 whp
Old Sep 13, 2006 | 08:12 PM
Schister66's Avatar
Man U FTW
11lb here and making 275whp, but i'm going for more on the same one.....
Old Sep 14, 2006 | 05:03 AM
4thgenx42's Avatar
Yeah if you're a good driver it isnt bad. Its just that its going to be a pain having to rev that engine in order to take off if you daily drive this car.
Old Sep 14, 2006 | 05:54 AM
oscarmayer's Avatar
Your not really going to notice anythign in shifting, but you will notice a much faster responding engine. unless your building a full road race style car not for the street, there's no reason not to use a aftermarket lightened flywheel. they are stronger, lighter, and give you way more benefits. they even offer hp that has been dyno measured due to less rotational mass= more power.
for $200 you can't find a cheaper way to get that kind of over all benefits.
I tun a build D with about 400 hp @20psi and mine runs awesome. so I'm speaking from expirnece not from hear say. Anytime I've worked with or on a project a alloy flywheel was always one of the things at the top of the lsit.
Old Sep 14, 2006 | 06:33 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (4thgenx42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenx42 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah if you're a good driver it isnt bad. Its just that its going to be a pain having to rev that engine in order to take off if you daily drive this car.</TD></TR></TABLE>
Have you Ever driven a car with a lightweight flywheel?
Because losing any driveability is complete bs ..
Old Sep 14, 2006 | 11:46 AM
95dc2teg's Avatar
Default Re: (CleanLikeJdm)
Thanks for the posts guys, I just ordered my ACT xtss with a prolight flywheel, Ive never driven a car with a lightened flywheel so I guess im just going to have to get used to it. Im only running 7psi on a stock gsr motor so im assuming it wont be a problem. I will let you all know how it feels after the install!
Old Sep 14, 2006 | 12:53 PM
95dc2teg's Avatar
Default Re: (95dc2teg)
i have another question....when you say if you shift fast you wont have a problem. is that because the revs fall faster with a lighter flywheel?
Old Sep 14, 2006 | 08:06 PM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">i have another question....when you say if you shift fast you wont have a problem. is that because the revs fall faster with a lighter flywheel?
i would say that dude has does not have light flywheel.
find someone that has one in the area and drive it. you will be perfectly fine.
platinum.
Old Sep 15, 2006 | 07:33 AM
95dc2teg's Avatar
Default Re: (platinum00)
How much do stock gsr flywheels weigh?
Old Sep 15, 2006 | 07:59 AM
I think the stock b16/gsr flywheels are around 17-20lbs, and don't listen to that guy. Driving your boosted gsr with a lightened flywheel will be the same, the only difference might the pedal feel since the ACT clutches have faster engagement than stock. It will drive the same as it does now, nothing crazy, but you will notice an increased throttle response, which is the reason why you upgraded your flywheel.
Old Sep 15, 2006 | 08:44 AM
95jeremie's Avatar
Default Re: (Mugencrxsir1)
10 lb fly on my SOHC not boosted (yet... I'm working on it ) but I LOVE it so far my favorite upgrade so far. the response is great!!! i have a CC pro street stage 2 clutch and well you get the point. DO IT!!!!!
Old Sep 15, 2006 | 09:32 AM
95dc2teg's Avatar
Default Re: (95jeremie)
It should be in today, and I will probably get it installed on monday. So im pretty excited! Is it difficult to change a clutch out urself? Im not bad at installing things or changing parts out but ive never tried a clutch......
Old Sep 15, 2006 | 11:45 AM
Everyones Hero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">It should be in today, and I will probably get it installed on monday. So im pretty excited! Is it difficult to change a clutch out urself? Im not bad at installing things or changing parts out but ive never tried a clutch......</TD></TR></TABLE>
It's a bitch to drop & put the tranny back on. Other than that it's easy.
I have a 7lbs Fidanza and I can't tell the difference between it and my stock Z6 flywheel.
Old Sep 17, 2006 | 03:31 PM
PickleTeg's Avatar
Default Re: (Everyones Hero)
I just put a 12lb one with the ACT HDSS in my Teg. It is NOT hard to drive at all. You have to be a little careful trying to takeoff, but it is nothing that you don't get used to in a few hundred miles.
Old Sep 17, 2006 | 05:21 PM
ej8's Avatar
ej8
Default Re: (PickleTeg)
I ran a 7lbs flywheel with my boosted civic and loved it, one of the most noticable upgrades for sure. And dont listen to the people who say its too light or you cant daily it because they have never driven on one, you get used to it really fast. Revs really nice and engine braking is superb as well.
VtecInteg95
Dec 11, 2003 03:04 PM
lilman36
Nov 20, 2003 12:00 PM
etmoron
Aug 1, 2003 08:20 PM
FORTIS
Feb 12, 2002 08:52 AM
lucas569
Aug 6, 2001 02:14 PM
