building a turbo kit..help needed
Old Sep 8, 2006 | 06:17 PM
gsr_pimp88's Avatar
Default building a turbo kit..help needed
ok so i want to build a turbo kit and get the parts individually cuz the bolt on kits are really expensive, but i dont know where to start. i have done research and searched around but i dont know much about turbos or anything forced induction. i dont know which parts are good quality or which brands go best with the other. i dont want to be runnin more that 8psi becuase this is my daily driver. any help with prices, brands, types, websites would help ALOT thanks
EDIT: for a stock 01 GSR, budget around 1500 - 2000, but the cheaper the better
Modified by gsr_pimp88 at 11:02 PM 9/8/2006
Old Sep 8, 2006 | 06:58 PM
urbansi's Avatar
Default Re: building a turbo kit..help needed (gsr_pimp88)
First off what car/motor and whats the budget???
Old Sep 8, 2006 | 07:02 PM
gsr_pimp88's Avatar
oops its for a stock 01 GSR, budget around 1500 - 2000, but the cheaper the better
Old Sep 8, 2006 | 07:24 PM
Mugencrxsir1's Avatar
Default Re: (gsr_pimp88)
custom kit, piecing it together is your only bet for under 2k. Plus it's a good way to get the parts you want....
Old Sep 8, 2006 | 09:05 PM
dpetro1's Avatar
Default Re: (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_pimp88 &raquo;</TD></TR><TR><TD CLASS="quote">oops its for a stock 01 GSR, budget around 1500 - 2000, but the cheaper the better</TD></TR></TABLE>
maybe the most junkyard setup can be had for that budget. but honestly a decent turbo setup is gonna run you 3-4k. the turbo hardware itself may not be too much. but you must figure in injectors, fuel pump, engine management and all that good stuff as well. a pump, injectors, ems and conversion harness, and a tune alone will probably run around 1k or more so there is half your 2k budget right there.
research and do it right the first time. ps brands like garrett, precision, and tial come to mind just to name a few. GL
Old Sep 9, 2006 | 06:10 AM
gsr_pimp88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">custom kit, piecing it together is your only bet for under 2k. Plus it's a good way to get the parts you want....</TD></TR></TABLE>
yea thats what i want to do but dont kno exactly where to start
Old Sep 9, 2006 | 06:22 AM
aaroboost's Avatar
actually you can pretty easily do a turbo kit for 2000, tune included, i think. Im working on it now, and plan on not spending much more than 1500. Ive got a couple ebay parts, and mostly used parts from the classifieds here on hondamarketplace. just make a list of everything youll need, including a tune, and start budgeting prices. then, just wait for the deals. A street tune will only runyou a couple hundred bucks, plus another couple hundred for a chipped ecu and conversion harness. Just keep doing lots of searching, youll figure it out
Old Sep 9, 2006 | 06:25 AM
gsr_pimp88's Avatar
yea but the thing is with a lot of searching, i still dont know exacctly what i need to get to make a complete set, can someone give me a list of things i would need to get so i know what exactly to look for?
Old Sep 9, 2006 | 06:53 AM
8200RPM's Avatar
local hippie
I, along with maaaany other people out there, have pieced together a kit...
heres a link to my setup... that should help.
https://honda-tech.com/zerothread?id=1636637
Old Sep 9, 2006 | 07:16 AM
aaroboost's Avatar
alright heres a quick list off the top of my head...
manifold
turbo
wastegate
downpipe
dumptube
intercooler
ic piping and couplers
bov
injectors
resistor box (if using dsm)
fuel pump
ecu
conversion harness
oil lines
boost guage
tune
exhaust?
youll probably need a slim fan
other miscelaneous hardware and fittings
Old Sep 9, 2006 | 07:44 AM
gsr_pimp88's Avatar
Default Re: (8200RPM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8200RPM &raquo;</TD></TR><TR><TD CLASS="quote">I, along with maaaany other people out there, have pieced together a kit...
https://honda-tech.com/zerothread?id=1636637</TD></TR></TABLE>
damn man...how much that cost u?
Old Sep 9, 2006 | 08:05 AM
8200RPM's Avatar
local hippie
Default Re: (aaro-boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaro-boost &raquo;</TD></TR><TR><TD CLASS="quote">alright heres a quick list off the top of my head...
manifold
turbo
wastegate
downpipe
dumptube
intercooler
bov
injectors
fuel pump
ecu
conversion harness
oil lines
boost guage
tune
exhaust?
other miscelaneous hardware and fittings</TD></TR></TABLE>
I believe it was about $1700...roughly
Old Sep 9, 2006 | 09:02 AM
gsr_pimp88's Avatar
where did u get most of your stuff? online? which is the best place to get it
Old Sep 9, 2006 | 09:18 AM
Dollar_bill
Guest
Posts: n/a
With your budget you might want to source the parts you need from reputable forum members or sit out another year and save enough to get a good turbo kit,preferbly a new kit not someones old beaten used parts.Cheap is not allways good.Good luck
Old Sep 9, 2006 | 02:20 PM
8200RPM's Avatar
local hippie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr_pimp88 &raquo;</TD></TR><TR><TD CLASS="quote">where did u get most of your stuff? online? which is the best place to get it</TD></TR></TABLE>
turbo from camp1320.com
wastegate from b18bturbo on here if memory serves me right
uum... the injectors from a fellow h-t'er, bov from ebay, ecu from a friend, exhaust piping from a friend, conversion harness from a friend, oil lines and couplers from napa, manifold/dp and piping my bf made-hermsfab.com...
if you search on here, there are several threads that will help you with exactly what youre looking for.
RA217252
Jan 23, 2008 04:21 PM
Ricer4life15
Jul 11, 2005 09:19 PM
badasshatchhh
May 16, 2005 05:26 PM
hinds90
Feb 14, 2005 03:37 PM
dom5372
Jan 23, 2005 11:24 PM
