idleing problems after JRSC install please read!!
Old Sep 11, 2006 | 07:27 AM
95civicSirCoupe's Avatar
Default idleing problems after JRSC install please read!!
Finished JRSC install on my d-series. everything seems to run fine however i get wierd idleing. On a cold start it will rev to about 1200 then after a few it will even out to around 700 but then after runnig it will flirt with the 100 range up down updown. then if i drive and put the car in nuetral as i roll to a stop the car will drop idle and die.
Facts: after install i havent checked nor adjusted timing. Boost gauge shows vacum at 20 at idle is that normal????
Old Sep 11, 2006 | 07:51 AM
Default Re: idleing problems after JRSC install please read!! (95civicSirCoupe)
bump bump bump
Old Sep 11, 2006 | 07:53 AM
gitwidit's Avatar
did you relocate and reinstall the pcv valve?
Old Sep 11, 2006 | 11:11 AM
Default Re: idleing problems after JRSC install please read!! (gitwidit)
what you mean relocate it. i reinstalled it and tied it to my lines connected it to my firwall
Old Sep 11, 2006 | 05:34 PM
sc4dr's Avatar
You might have a vaccum leak somewhere.
95civicSirCoupe
Sep 11, 2006 07:49 AM
Liquid Ice NF
Oct 9, 2005 10:43 AM
CKim
Aug 31, 2001 11:59 PM
