5 MAIN GIRDLE or 3 MAIN
Old Sep 8, 2006 | 08:51 AM
WVTURBOCRX's Avatar
Default 5 MAIN GIRDLE or 3 MAIN
I have a B16A1, my question is... Is a Girdle really nessesary?
The motor will be over 400hp.
There is also the question whether it should be a 3 point or 5.
Who knows this solution?
Old Sep 8, 2006 | 09:14 AM
WVTURBOCRX's Avatar
Default Re: 5 MAIN GIRDLE or 3 MAIN (WVTURBOCRX)
What about just using a GSR 3 point girdle? They are cheaper and can get them from a local junk yard.
Old Sep 8, 2006 | 09:32 AM
urbansi's Avatar
Why not just pick up a GSR short block and build that with the b16 head, expecially since i have never been to a junk yard that has spare GSR motors just laying around.
Old Sep 8, 2006 | 09:51 AM
WVTURBOCRX's Avatar
Default Re: 5 MAIN GIRDLE or 3 MAIN (urbansi)
I have had ERL Sleeve the motor.
Old Sep 8, 2006 | 09:53 AM
urbansi's Avatar
Ahh i see, and did you think about asking ERL what their opinion on doing a main girdle is.
Old Sep 8, 2006 | 10:14 AM
WVTURBOCRX's Avatar
They said send it back and they will install it...
That is not the question, so replying if your going to be a smart a**.
Is it nessesary or not to have the girdle?
Old Sep 8, 2006 | 10:23 AM
urbansi's Avatar
Well here is the thing, a shop is going to advise you to do something if it generates them profit, now i am not trying to be a smart *** when i ask what they had to say, its just an honest question.
What i would try doing if you already havent, is do a search and see what people with sleeved b16's do when it comes to bottom end support aside from main studs. Even try pm'ing Earl or some of the engine builders on this site and ask what their opinion is.........they will answer your questions, even if you are not paying for their service, thats what this site is for.
GL
Old Sep 8, 2006 | 10:27 AM
urbansi's Avatar
And if you did do a search and all you found was for sale **** try searching under post bodies and limiting your search to forced induction, i did this and i got one answer that seemed somewhat informative
"a b16, it has a very short stroke therefore its not needed. why do you think the gsr and type r come stock with a girdle? its because honda took years and years of development and finding the weak points and correcting them. the reason an LS doesnt have one is that its only designed to rev to 7200rpm so its not needed"
Old Sep 8, 2006 | 10:47 AM
WVTURBOCRX's Avatar
Now that's good feedback...
Old Sep 8, 2006 | 11:30 AM
Turbo-LS's Avatar
Absolutly NO need for a girdle on a b16. short stroke and a well balance will do you just fine to 10k. IF you really want one then dont mess around with a gsr one because that invlolve lin boring and all sorts of gay **** to make the caps work properly. go on ebay and get a KMS 3 main girdle. its superior to the gsr one and its only 140 bucks and will bolt right in on any b16 or ls main caps
Old Sep 8, 2006 | 12:29 PM
urbansi's Avatar
Default Re: 5 MAIN GIRDLE or 3 MAIN (Turbo-LS)
I no that Z10 also makes a girdle, i looked into for my motor build but in the end i decided to spend money other ways.
Old Sep 8, 2006 | 01:14 PM
RedEj8's Avatar
I was under the impression that anytime you install a girdle in any block that didnt come with one from the factory(or a 5main girdle in one that orginally came with a 3 main), it is necessary to aling hone the mains. Any truth to this?
Old Sep 8, 2006 | 01:16 PM
urbansi's Avatar
Default Re: 5 MAIN GIRDLE or 3 MAIN (RedEj8)
Ask Earl
Old Sep 8, 2006 | 01:19 PM
WVTURBOCRX's Avatar
I have never seen Z10 before till now... Looks like they have some great stuff.
Also your correct as we all know it's fast to drop thousands into these projects, I believe I will invest it into another area.
dutchman5
Jan 8, 2007 04:55 AM
JUNEK9
Dec 21, 2004 03:21 PM
Reverend
Nov 11, 2001 12:51 PM
