what radiator cap lbs to get
Old Sep 8, 2006 | 06:15 PM
importdude2000's Avatar
Default what radiator cap lbs to get
recently if i hit a big dip on freeway it will start to climb temps
first thing i would like to try to get a rad cap first
should i get the one that holds more ? or stock?
currently has a 13lb stock one
im thinking of getting the 16lb one...(morelbs) holds more pressure right?
thx
Old Sep 8, 2006 | 06:21 PM
Muckman's Avatar
Moderator in Chief
Default Re: what radiator cap lbs to get (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">recently if i hit a big dip on freeway it will start to climb temps</TD></TR></TABLE>
Read this sentence back to yourself and tell me if it makes sense to you, honestly.
Old Sep 8, 2006 | 06:54 PM
urbansi's Avatar
Default Re: what radiator cap lbs to get (Muckman)
My pwr is 16lbs and actually seems to be just fine, its not like its hard to switch back and forth, i know that the nissian caps are interchangable so.........
Old Sep 8, 2006 | 08:31 PM
qfast817's Avatar
Default Re: what radiator cap lbs to get (urbansi)
thx</TD></TR></TABLE>
did you crack the radiator?
Old Sep 8, 2006 | 08:46 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">recently if i hit a big dip on freeway it will start to climb temps </TD></TR></TABLE>
Been having the exact same problem. Found out that it was air bubbles tonight. Sooo I used a handy little tool....it creates a vaccum and sucks the air out and then pushes coolant in the system to make sure there are zero air bubbles. It then took me seriously like at least an hour to get all the bubbles out. Gotta love changing the coolant from like 5:45-8:45 haha BUT the problems are solved.
Old Sep 8, 2006 | 08:55 PM
mike93eh2's Avatar
13 lbs.
OUT_OF_ORDER_DB7
Northern California (Sales)
Oct 4, 2007 07:12 AM
twenty
Jul 2, 2005 10:22 AM
B2FiNiTY
Jan 25, 2005 06:27 PM
suckawillis
Dec 24, 2004 09:15 PM
B_1_8_hatch
Jul 15, 2003 09:22 PM
