stripped oil feed
Old Sep 10, 2006 | 04:27 PM
TypeSLO's Avatar
Default HELP: stripped oil feed
the hole in the back of this block for the oem oil pressure sending unit is partially stripped. what can i use to fix this? i gotta get the new 1/8 bsp fitting in there... thanks.
Modified by TypeSLO at 5:38 PM 9/10/2006
Old Sep 10, 2006 | 05:36 PM
97turboteg's Avatar
Default Re: HELP: stripped oil feed (TypeSLO)
i had the same problem, thats what happens when you let friends that THINK they know what there doing work on your car... What I did, was took the OP sending unit out, chemically cleaned the hole with a paper towel until i didnt get any oil on the towel, then put JB Weld on the OP sending unit, screwed it back on gently, then put JB around the block and OP sending unit, try that. IF not, you will have to pull the motor and tap and dye it...let us know how it goes, good luck man
Old Sep 10, 2006 | 07:18 PM
SovXietday's Avatar
Default Re: HELP: stripped oil feed (97turboteg)
You can get 1/8 BSP taps, hopefully since your only partially stripped screwing that in will rethread it. That's what I had to do, worked but I really hate that part of the block.
Old Sep 11, 2006 | 04:52 AM
TypeSLO's Avatar
Default Re: HELP: stripped oil feed (SovXietday)
who carries a 1/8bsp tap? i looked all over. maybe napa?
Old Sep 11, 2006 | 05:59 AM
playahwitgame's Avatar
i dont see them everywhere, u may need to just order it online somwhere
Old Sep 11, 2006 | 12:40 PM
TypeSLO's Avatar
Default Re: HELP: stripped oil feed (playahwitgame)
thinking of just retapping it with a 1/8 npt. should be pretty close. what do you guys think?
PinkMaggit
May 21, 2008 12:47 PM
gutted
Aug 20, 2005 09:55 PM
Mr HYDE
Welding / Fabrication
11
Jul 18, 2005 11:08 AM
Mr HYDE
Jul 12, 2005 06:31 PM
redboost10
Dec 9, 2003 01:15 AM
