14b with ps
Old Sep 9, 2006 | 07:28 PM
wrinkles's Avatar
Default 14b with ps
is it possible to keep power steering with a 14b with HF manifold?
Old Sep 10, 2006 | 07:11 PM
wrinkles's Avatar
anyone?
Old Sep 10, 2006 | 10:36 PM
HeedLessInc's Avatar
Default Re: (K Stef)
you can keep the p/s but not the a/c unless you mod something crazy!
Old Sep 10, 2006 | 10:51 PM
exotik4doorcivic's Avatar
Default Re: (HeedLessInc)
you need to cut the compressor outlet pipe (the one that bolt onto the turbo) and reweld it or clock the turbo
go to homemadeturbo.com it will show you everything you need to know
i have a d16z6 14b hf manifold dsm 450cc injectors running 9lbs tuned 190 whp
Old Sep 11, 2006 | 08:15 PM
wrinkles's Avatar
Default Re: (exotik4doorcivic)
where did you get that from? i need one!
edit: i have already removed ac but planned on keeping the ps good to know i can keep it
Old Sep 12, 2006 | 11:29 AM
that outlet pipe comes off the stock turbo yours should have came with it
it bolts on top of the outlet of the turbo
you just need to cut the pipe and re weld it at a different angle because the way it is stock hits the power steering pump
Old Sep 12, 2006 | 02:09 PM
wrinkles's Avatar
mine didnt come with it so i guess ill try a junk yard unless someone sells them
p.s. is that a flex pipe on your charge pipe?
Old Sep 13, 2006 | 09:42 PM
that was not my setup, it was someones from homemadeturbo.com
i have everything he bassically has though just didnt feel like posting my setup
d16z6
14b
hf manifold
dsm 450cc injectors with resistors
tuned on chrome pro 9lbs
stealthmode oil line
2.5 in piping
3 inch downpipe
2.5 thermal r & d catback
EJ8 GSR-T
Sep 11, 2005 11:45 AM
RACEPAK
Sep 28, 2004 10:39 PM
crooked muffler
Feb 16, 2003 07:16 PM
APEXI Si
Jan 9, 2003 08:52 PM
