Y8 - Dyno & Street Tuned This Weekend: 205whp/174ft-lbs 10psi
Hey guys.
On Saturday I drove up to Tampa to get tuned by John Vega. It was a great experience. The car feels awesome. We had a little bit of a boost drop off, possibly due to a minor boost leak. Damnit! Making this power at around 10 pounds of boost. Spent about 2 hours on the dyno and half an hour on the street. Props to Vega!
Set up details:
1999 CIVIC EX, D16Y8 (205 whp 174 ft-lbs @ 10 psi)
Garrett T3/T04E 50 Trim .48 a/r
BMC (JG Fab) AC Log/2.5" Downpipe & Dumptube
Tial 38mm W/G & Turbo XS MBC
HKS SSQV BOV
JRC 6" I/C
ATP Turbo Silicone Clamps & Couplers
Stealthmode Oil Line Kit
Walbro 255lph HP
RC 440's
Chipped ECU (tuned by John Vega @ Phearable.net)
Autometer Sport-Comp's: Oil Press, Boost/Vac, Fuel Press
3" Exhaust (no cat/no res) to an Apexi WS2 Turbo Muffler
ACT XTSS
Modified by tucked_civ99 at 2:06 PM 9/11/2006
Modified by tucked_civ99 at 5:45 PM 9/11/2006
Set up details:
HKS SSQV BOV
JRC 6" I/C
Walbro 255lph HP
RC 440's
ACT XTSS
big strong guy
Re: (tucked_civ99)
Sweet Car man, You have a Very Clean setup...
When john over layed your graph on that other 99 EX that day You had a sweet mid range!
Look for a boost leak... Perhaps?
Eric
Eric
Re: (rainmanEK)
thanks man. yeah i'm going to have to look all over for a boost leak. you saw how tight i had those t-clamps on! i'm thinking i'm losing some pressure on the fpr line. i'm going to change them tomorrow and see what happens.
Re: Y8 - Dyno & Street Tuned This Weekend: 205whp/174ft-lbs 10psi (tucked_civ99)
Nerdsports has that same turbo and at 12 psi he made 270 something whp and over 220 ftlbs of torque
Was the timing messed with at all (i know its a touchy subject when dealing with y8/crome or uberdata setups)
Re: Y8 - Dyno & Street Tuned This Weekend: 205whp/174ft-lbs 10psi (willyboyK20)
Glad the setup made a smooth powerband & you enjoyed it :-)
The setup was tuned to the max....
The setup was dropping off boost by 2-3 psi at the end of the power band.
I believe there is a boost leak somewhere which is causing the loss of boost
Re: Y8 - Dyno & Street Tuned This Weekend: 205whp/174ft-lbs 10psi (mtber)
john is it possible that i could lose that much boost from the tees at the fpr to the boost gauge and bov? that seems to be the only weak spot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tucked_civ99 »</TD></TR><TR><TD CLASS="quote">john is it possible that i could lose that much boost from the tees at the fpr to the boost gauge and bov? that seems to be the only weak spot?</TD></TR></TABLE>
Did you do the pressure test yet & found air escaping from those connections ?
not yet, thats just a guess. i should have an answer soon. I'll keep you posted.
