Blow'n headgasket.. Need Help!
Old Sep 11, 2006 | 12:18 PM
srg's Avatar
srg
Default Blow'n headgasket.. Need Help!
Hello,
Today I've blow'n headgasket.. Engine is D16z6.. What should I do? Engine is stock, Let me know which headgasket is best to use on stock engine.. and what is arp headstuds?
Thanks
Old Sep 11, 2006 | 02:34 PM
srg's Avatar
srg
bumpy need help
Old Sep 11, 2006 | 02:40 PM
N20civicB18's Avatar
Default Re: Blow'n headgasket.. Need Help! (srg)
OEM Honda Headgasket, Head studs are just a stronger aftermarket head bolt you want ARP - contact Summit Racing or Jegs
Old Sep 11, 2006 | 02:55 PM
SOHC_MShue's Avatar
get a new oem gasket and arp studs. Recheck your tune as well. Probably too much timing.
Old Sep 11, 2006 | 03:29 PM
srg's Avatar
srg
Default Re: Blow'n headgasket.. Need Help! (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">get a new oem gasket and arp studs. Recheck your tune as well. Probably too much timing.</TD></TR></TABLE>
I'm running 1deg/PSI..
Wastegate spring is 0.5bar
Thanks a lot guys! So is it good idea to run arp headstuds? or is it waste of money?
Old Sep 11, 2006 | 04:05 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srg &raquo;</TD></TR><TR><TD CLASS="quote">I'm running 1deg/PSI..
Thanks a lot guys! So is it good idea to run arp headstuds? or is it waste of money?</TD></TR></TABLE>
fyi i've found slight knock using knock detection devices on a number of sohc's running a 1deg/psi retard with 11.5:1 afr's in boost.
blackccoupe
Aug 27, 2008 08:52 PM
jarven093
Mar 3, 2007 10:39 PM
JDMSi92
Nov 29, 2005 05:29 AM
DB1_559
Nov 26, 2005 02:52 PM
H23vtecEG
Apr 28, 2003 06:43 PM
