Blox H22 cams
I've been wondering if anyone has tried there cams there are 3 types of cams I guess and need to know if anyone has specs or info on them. I need info on
Tuner Series - Uses OEM camshaft lobe designs, with BLOX profile specifications.
- Type A: Okay to use with factory valvetrain components.
- Type B: Strongly recommend using with Blox dual valve springs.
- HSL (High Speed Lift): Must use with Blox dual valve springs and Ti retainers.
- Turbo: Strongly recommend using with Blox dual valve springs and Ti retainers.
Competition Series - Cast with wider primary and secondary lobes, with Blox profile specifications
- Type C: Must use with Blox dual valve springs and Ti retainers
There are a few companies out that carry these cams like Tom at Camp1320 Password JDM, Weaksauce racing and so on but they don't have much info that they can disclose to me. Any help would be appreciated.
Thanx Raymond
Thanx Raymond
a lot of us B series guys are using all motor cams. i will soon be puttin pro1's into my vehicle. most of the h22 cams on the market are very mild profiles.
PM me if you're interested in specs and pricing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">a lot of us B series guys are using all motor cams. i will soon be puttin pro1's into my vehicle. most of the h22 cams on the market are very mild profiles.
So do u have spec's on these blox cams if so can u please post so we can all
know what were buying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dollar_bill »</TD></TR><TR><TD CLASS="quote">Do you have the specs of these cams lift,duration etc?</TD></TR></TABLE>Thats what I'm trying to find out so I can pick which one would be best for my setup.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 »</TD></TR><TR><TD CLASS="quote">I'm still hearing that there are no H22 aftermarket cams for use with turbos, that do any better than the stock or H22 'S' type cams.</TD></TR></TABLE>
Stock and hype-S cams are crap I want something that will make power and hold all the way to 8500 to 9000.
</TD></TR></TABLE>So do u have spec's on these blox cams if so can u please post so we can all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 »</TD></TR><TR><TD CLASS="quote">I'm making 464 whp @ 8000 @ 18 psi on a .82 afr GT30 with hp still increasing. Some of the big name racers @ 7-800 + whp, use stock and 'S' cams. - ask them.</TD></TR></TABLE>
Ya I really dont think the 7 to 800+ H22 guys are using stock or even type-S Cams most of them are using custom grinds for there setup.Not to sure where u got that from but most H22 peps wont really give out there engine info.
Jason @ RAGE in an article in TURBO about a year ago. Same feedback from DH. Other articles in mags, one on a record holding prelude. Some may use custom grinds but it seems like there are a number on stock cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ray-mond »</TD></TR><TR><TD CLASS="quote">So do u have spec's on these blox cams if so can u please post so we can all
Stock and hype-S cams are crap I want something that will make power and hold all the way to 8500 to 9000.</TD></TR></TABLE>
blox stage II's
INT: Dur-272 Lift- 505
EXH: Dur-278 Lift- 469
Duration measured at .040
blox stage II's
blox stage II's
Duration measured at .040</TD></TR></TABLE>
wow Thanx alot.
Just the ones I wanted to know.
blox stage II's
wow Thanx alot.
wunfstgsr
Apr 26, 2008 03:11 PM
