Ignition timing retard
Old Sep 8, 2006 | 03:26 AM
NLR's Avatar
NLR
Default Ignition timing retard
So what are you guys using for retarding ignition timing on low boost applications?
Thanks,
seb
Old Sep 8, 2006 | 04:03 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Ignition timing retard (NLR)
well usually on a stock internal fmu'd car at low boost, we just knock 2* off at the dizzy. but most use the MSD BTM. but now it is mainly in the e.m.s.
Old Sep 8, 2006 | 06:57 AM
DaveF's Avatar
Default Re: Ignition timing retard (boostedcivicsir)
engine management systems......
Old Sep 9, 2006 | 04:29 AM
NLR's Avatar
NLR
Default Re: Ignition timing retard (dturbocivic)
so there really is no need for a small device that would retard timing via boost pressure or over time that would connect to the distributor( doesnt matter if its hall or mag)
Old Sep 9, 2006 | 04:48 AM
DaveF's Avatar
isnt that what msd btm does ??
Old Sep 9, 2006 | 06:31 AM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NLR &raquo;</TD></TR><TR><TD CLASS="quote">so there really is no need for a small device that would retard timing via boost pressure or over time that would connect to the distributor( doesnt matter if its hall or mag)</TD></TR></TABLE>
Not when you can socket a stock ECU and tune it with an application that is free or very inexpensive.
Tad
Dec 17, 2003 03:10 PM
boost fed ls
Jul 20, 2003 09:43 AM
swlabhot
Mar 10, 2003 02:27 PM
