Upgrading MAP sensor...When??
Old Sep 12, 2006 | 06:54 PM
vg7z's Avatar
Default Upgrading MAP sensor...When??
When would u need to upgrade your stock MAP sensor?? thanks
Old Sep 12, 2006 | 07:02 PM
20yrsToMidnight's Avatar
Default Re: Upgrading MAP sensor...When?? (vg7z)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vg7z &raquo;</TD></TR><TR><TD CLASS="quote">When would u need to upgrade your stock MAP sensor?? thanks</TD></TR></TABLE>
i'd get one if you were planning on running more then about 9 or 10 pounds. I've heard they can see 11psi but its just safer and they arnt to expensive.
Old Sep 12, 2006 | 07:07 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Upgrading MAP sensor...When?? (20yrsToMidnight)
your stocker can read to 11.2 psi. you can tune past that, but it is safer to use an ems that has 3 bar capabilities. and again you can only go to 27 and change but can tune the last column fat and get it higher, and then you need to step to a (is there a 3.5 bar? im goin 5 anyway) bigger one from there.
Old Sep 12, 2006 | 07:20 PM
OBRJosh's Avatar
Default Re: Upgrading MAP sensor...When?? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">your stocker can read to 11.2 psi. you can tune past that, but it is safer to use an ems that has 3 bar capabilities. and again you can only go to 27 and change but can tune the last column fat and get it higher, and then you need to step to a (is there a 3.5 bar? im goin 5 anyway) bigger one from there.</TD></TR></TABLE> Aem makes a 3.5 bar
boostek9
Engine Management and Tuning
Sep 7, 2008 08:43 PM
Kid_SiR
Dec 28, 2007 03:07 AM
crawlin
Sep 12, 2007 02:01 PM
Greg H
Sep 23, 2006 06:58 AM
Topdawgg
Jan 18, 2006 05:15 PM
