D series build up help!!!
Old Sep 8, 2006 | 06:46 PM
nichols_si's Avatar
Default D series build up help!!!
Hey guys!!
so yea my stock z6 blew ring lands are toast. needing some advise on how to go on this re build. I dont wanna do anything to crazy . like 220whp etc daily driver an be durable.
i understand, need pistons & rods.. I dont plan on running it past redline , so that being i do not need valve train?
some help from the ever so great HT experts for FI
thanks, any advise on specific brands of parts etc i should go with id like that thanks
darcy
Old Sep 8, 2006 | 06:56 PM
urbansi's Avatar
Default Re: D series build up help!!! (nichols_si)
Really depends on your budget, what do you have to spend.
Budget- SRP's with eagles
Baller-sleeved, CP's(does manley make d-series rods) if so manley.
And believe me 220whp gets old real real fast.
Old Sep 8, 2006 | 06:58 PM
nichols_si's Avatar
SRP? kinda confuzed u mean .. no sleving for me about 2gs almost lil les s
Old Sep 8, 2006 | 07:01 PM
SovXietday's Avatar
Default Re: (nichols_si)
Budget = Vitara and Tuner Toys, lol.
Common = Wiseco/CP/Endyn/SRP and Eagles
Baller = Sleeved, CP, and Pauter
I'd get some CP/Wiseco's in there along with Eagle rods personally, that way when you get bored of 220, you can push it a bit further.
Old Sep 8, 2006 | 07:08 PM
nichols_si's Avatar
k sounds good... so jsut basic then
rods , pistons? .. special head gasket etc or obviouisly arp studs etc
Old Sep 8, 2006 | 07:13 PM
93supercoupe's Avatar
stock gasket and ARP headstuds, injectors and fuel pump
Old Sep 8, 2006 | 11:58 PM
broketuner-Sol_Si's Avatar
Default Re: (93supercoupe)
I say go with vitaras, shotpeened LS rods and ARP bolts, much cheaper than aftermarket combos and just as reliable...with the lower CR you can even boost a little bit more just as safely as stock. If you haven't done so already I'd also check into upgrading the cam since I'm assuming the motor is already out.
Stanceman
Jan 12, 2021 04:19 AM
marcussmith26
Jan 5, 2006 06:36 PM
infinatenexus
Feb 26, 2004 06:32 PM
batman_22
Dec 12, 2002 11:58 AM
AudioXtremes
17
Jan 29, 2002 03:08 PM
