cannot turn key
Old May 24, 2010 | 04:46 PM
the soL that could's Avatar
Default cannot turn key
i have a feeling it is this: part #1 06350-ST8-A44 KEY SET, CYLINDER (SERVICE)
looks simple enough to do myself... dealership charging me 700$. anything i should be aware of before i attempt to tear apart the steering column? Thanks~!
Old May 24, 2010 | 07:02 PM
90_EX_Civic's Avatar
Default Re: cannot turn key
you sure it's not just stuck? maybe your tumbles aren't dropping right? try to wiggle it a little?
Old May 24, 2010 | 07:19 PM
95 integra's Avatar
The bolts holding the lock cylinder on have big metal tabs bent over them and are a bitch to get out. I'd just replace the actual lock. Also, are you sure it isnt the steering wheel lock?
Old May 24, 2010 | 08:22 PM
alphalanos's Avatar
Make sure its not the steering wheel lock. My key was getting stuck more and more until one day I almost snapped the key head right off I was turning it so hard. Anyway its not too hard to replace. Take off the plastic covers, a couple bolts drop the column down, drill out the old bolt heads on the clamp, and unplug some stuff.
Old May 25, 2010 | 07:47 AM
follie gatts's Avatar
a lot of times the key is just inserted too far. by wrenching on it in frustration you are putting way too much force on the key. slide it out of the lock by 1 or 2 millimeters and try turning it gently. every time my key doesn't turn it is simply too deep in the lock.
Old May 25, 2010 | 11:09 AM
what do you folks mean by "steering lock"? my steering wheel/tires are straight... how do i "replace the lock" only? i want to install an remote starter if all else fails.
Fast510
May 19, 2014 09:33 AM
1stgenboost
Feb 25, 2009 09:24 PM
whiteknightef
Mar 19, 2007 11:09 AM
syked
15
May 20, 2005 11:49 AM
Flamenco-T
Nov 19, 2002 07:32 PM
