Define: LS/VTEC.
Old Mar 26, 2002 | 07:36 PM
ebelp's Avatar
Default Define: LS/VTEC.
Quick question: what is the difference between an LS/VTEC engine, and the GSR motor?
Old Mar 26, 2002 | 07:40 PM
d8168055's Avatar
Default Re: Define: LS/VTEC. (ebelp)
LS have larger displacement... thus better bottomend torque...
Old Mar 26, 2002 | 07:44 PM
ebelp's Avatar
Default Re: Define: LS/VTEC. (d8168055)
Wait....is the LS/VTEC the B18C5 type r motor????
Old Mar 26, 2002 | 07:48 PM
d8168055's Avatar
no.. not that either... C5's are more like a modified C1... LS has a 1797 cc engine while the GSR and Type R have a little smaller... CORRECT me if i'm wrong... anyone have the correct numbers?
Old Mar 26, 2002 | 07:51 PM
ebelp's Avatar
Well what car does the LS/VTEC come in? Or if it's not a stock motor, what car did it come in??
Old Mar 26, 2002 | 07:55 PM
d8168055's Avatar
ok here are the correct numbers...
LS 1835 cc
GSR TYPER=1795 cc
ls/vtecs dont come in any cars.. we usually build them and put them in civics/integras... here is a site w/ good explainations... http://www.hondastyle.com/news/wmprint.php?ArtID=6
Old Mar 26, 2002 | 07:56 PM
SYDNEYSIDER's Avatar
LS VTEC is when you have an LS block and slap in on top either a b16 or a b18c1 head to have vtec. I don't have a clue about this set up but thats all I know. Search the board, I think its kinda costly.
Old Mar 26, 2002 | 07:57 PM
Aar99GSR's Avatar
It never came in a car its a hybrid swap. Put 2and 2 together. The LS you've got the torque. Add the VTEC and you have HP. So you have the best of both.
Old Mar 26, 2002 | 07:59 PM
dVs.'s Avatar
New User
LS/VTEC = LS integra bottom end + B18c1(GSR)/B18c5(TypeR)/any head with v-tec.
Basically the term can also be seen as any non-vtec bottom end combined with any v-tec head. Top end (the area with the camshafts), bottom end (area with the crank/rods/pistons).
If any of the above information is incorrect or someone has a problem with the way I put it you can just call me @ 1-800-makealistandgiveittomypsychiatrist.
junglistgsr's Avatar
Default Re: Define: LS/VTEC. (Aar99GSR)
LS/VTEC = b18a/b18b block + dohc b-series VTEC head
CRVTEC = b20 block + dohc b-series VTEC head
Old Mar 26, 2002 | 08:01 PM
Calavera's Avatar
LS/Vtec does not come in any stock cars. It's a kind of a hybrid.
It's when you add Vtec to your nonVtec engine (LS/RS/SE/GS engine).
I haven't looked much into this, but what you do is, swap out a few parts in an LS engine. Simply put, you put on a B16A(?)--not sure-- head on the LS engine. Of coarse it's a lot more complicated.
I gess the advantage of having LS/Vtec is that it's capable of the same output, if not greater than, that of a ITR. I've seen dyno charts of LS/Vtecs and they range anywhere from 160hp~200hp. Given that stock LS engines are 140hp, that's a pretty good increase.
Disadvantage of LS/Vtec's are that it's not reliable if not built correctly. It'll cost probably cost around ~$3500 if it's done by a reputable shop.
Sorry couldn't help you out that much, but I hope that now you know what you should search for.
Old Mar 26, 2002 | 08:12 PM
ebelp's Avatar
Default Re: Define: LS/VTEC. (Calavera)
Wow, that definitely clears things up. All I did was go brush my teeth and there were like 8 replies! Thanx.
Old Mar 26, 2002 | 09:22 PM
Muckman's Avatar
Moderator in Chief
That article was great!
Everyone talks about "the massive torque from the huge LS" "The best of both worlds" ? hah sounds like the story from a cheap f&cker who couldnt afford a B18c
lol its only 37cc's bigger than the GSR/ITR B18c(1,5) motors. 37cc's is not that much torque lol...
JDM-Rota
Aug 5, 2005 08:35 PM
97teggLS
Jun 1, 2004 08:20 AM
V8killa1.8
Jun 1, 2003 05:51 PM
Steve-o
Jan 28, 2003 08:14 AM
integra81
Nov 22, 2001 04:11 PM
