converting non abs axles to abs..
Re: converting non abs axles to abs.. (ILOVEGIRLS)
it is but why go thur all the trouble when you can get new axles very cheaply (non-oem) i buy gsr axles at the local parts stores around here for $60-$70 each...
Re: converting non abs axles to abs.. (lucas569)
cause i have these non abs axles, they are brand new and my car is abs equipped. thanks.
You need the abs pulser rings, which I don't know where you can get. Perhaps off a set of old abs axles. I was told you can just tap it off the old on and tap it onto a new one.
Re: converting non abs axles to abs.. (DarksideDC4)
so that ring's "tech name" is called a pulsar ring? ill se if acura has one to sell..thanks!
j0nptw
02-18-2005 10:12 AM
