Motor Flush?
Location: Formerly of SF moved to DFW and now back in SF, CA, USA
Re: Motor Flush? (98GeeYes-Are)
An old mechanics trick is to run a quart of auto tranny fluid through the engine for a minute making sure not to rev the engine and keeping it at idle (or you'll damage the engine). Than drain it all out, maybe flush the engine with a quart of oil and then fill it back up.
I don't see it in the owners manual nor in the service coupons (e.g. 30k, 60k, etc. service specials)
As long as you don't add Slick 50 or some other ****, and change the oil often and while the oil is hot, flushing is probably not needed.
Re: Motor Flush? (jl74)
I heard some motor flushes might contain some detergents that are too strong and harsh for our seals. I actually did GaryLube's ATF trick and my seals are just fine. Which reminds me I need to do another motor flush
I use stp engine flush at least twice a year. Pour in current oil, then start the car and run it at 2000 rpm for 10- 20 mins then drain the oil and change filters and replace with new oil. Trust me does no harm and you will be surprised what comes out.
STU
STU
EK-R Hatchman
30
04-27-2006 03:49 AM
