alternator
Old Mar 26, 2002 | 12:38 PM
Padronis's Avatar
Default alternator
I have changed my alternator 2 times in the last month. Original went bad, so I changed it. This one came out with a bad regulator. Now this one just decided to quit charging yesterday. It is really starting to **** me off, although I am really good at doing it now. Does anyone know what could be causing this to happen? I am beginning to wonder if something is causing this to happen.
[Modified by G2LSS, 3:38 PM 3/26/2002]
Old Mar 26, 2002 | 02:04 PM
Padronis's Avatar
Default Re: alternator (G2LSS)
Anyone?
Old Mar 26, 2002 | 05:32 PM
rjardy's Avatar
sounds like you just got a few bad ones, where are you getting it from. Try the dealership you can allways trust them. As to it being something on your car making them go out , theres nothing i could think of. Sorry i couldnt be of more help.
Old Mar 26, 2002 | 07:29 PM
Padronis's Avatar
Default Re: alternator (rjardy)
I will try this one more time, if it goes out, I'm going to the dealership to get one.
Old Mar 27, 2002 | 05:41 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Have you tried just swapping voltage regulators? They're external on the Integra alternators, no need to pull it apart or anything.
Old Mar 27, 2002 | 07:42 AM
96IntegraLS4DR's Avatar
Problem might be where you bought your alternator.
On G2IC board someone mentioned that Acura 's alternator spins opposite direction of other car's
alternator. If you were to put aftermarket on, there is a chance you ran into alternator that spins the wrong way.
Well, it will work for a while then will destroy itself b/c of heat.
Hope you still have original alternator.
If you do, take it to alternator shop and have it rebuild.
Old Mar 27, 2002 | 10:34 AM
Community Builder
Default Re: alternator (96IntegraLS4DR)
If you buy a Denso alternator made for the car there shouldn't be any problems from it spinning the wrong way. I found a website, Alternator Starter Express that sells remanufactured alternators and starters for many cars. I found one for a G3 Integra for $120 with 3 year warranty. If my alternator ever dies I'll probably buy one from there. I have a spare alternator that I tried to get apart to replace the bearings, but I never could get it apart all the way and ended up destroying the shaft where the pulley attaches to. Oh well, the one I have seems to be doing well now that I made the belt tension not so darn tight.
A 91 LS alternator is $105.
[Modified by PatrickGSR94, 1:37 PM 3/27/2002]
97elitehonda
Jan 3, 2008 07:54 PM
92silude
Jun 14, 2005 12:11 PM
BlackOut21
May 9, 2005 02:56 PM
BuBBa y0!
Aug 7, 2004 03:36 PM
Padronis
Mar 27, 2002 02:52 AM
