Changing Fule Filter??
Old Mar 27, 2002 | 05:42 AM
phatintegra's Avatar
Default Changing Fule Filter??
How often should u change your fuel filter?? Where is it on a 94 integra ls?? Will it give me any better gas mileage or throtle response or anyting?? what else should i replace its been about 40k miles since i tuned up my engine ?? spark plugs?? injectors?? should i clean anyting??
Old Mar 27, 2002 | 07:40 AM
Regular Series's Avatar
Default Re: Changing Fule Filter?? (phatintegra)
Yup, it's time! Get yourself a Haynes manual; they have a great walkthrough for changing a fuel filter. Haynes is not as comprehensive as the Helms, but it's a helluva lot cheaper and good for general tune up info.
Changing the fuel filter is really pretty easy, but BE CAREFUL! Remember, gasoline will light up from the tiniest spark.
Changing the filter can improve your fuel efficiency, idle, etc. Most importantly, a new fuel filter puts less strain on your fuel pump! That's definitely a big benefit! HTH
Old Mar 28, 2002 | 05:30 AM
integra81's Avatar
New User
Default Re: Changing Fule Filter?? (risingson77)
ttt
Old Mar 28, 2002 | 07:02 AM
egtech's Avatar
the fuel filter in your car is designed to be a lifetime filter. you only need to change it if your having fuel delivery problems.
you should however change your spark plugs, cap, and rotor.
hth
Old Mar 28, 2002 | 07:28 AM
FourDoorGSR's Avatar
Default Re: Changing Fule Filter?? (egtech)
I would have to disagree. Fuel filters just like any filter will not last the entire life of the car. I do not have the exact milage remembered off hand when you are supposed to replace the fuel filter, but I beleive it was between 60-90k miles
Old Mar 29, 2002 | 01:19 AM
kkim's Avatar
Default Re: Changing Fule Filter?? (FourDoorGSR)
I checked in my owners manual and the helms manual and I couldn't find a mileage interval for replacemnt. However, I am of the opinion that they should be changed. the helms says to put pressure gauges on the lines and see if they are up to spec... blah... blah... why bother? just change it at a reasonable interval. just did mine at 26k miles. may be all in my head, but I swear the car runs better after changing it. I'd say every 30 k miles is about right. filter was only $20. good luck.. and be careful when working with gasoline.
Old Apr 1, 2002 | 03:26 PM
integra81's Avatar
New User
Default Re: Changing Fule Filter?? (kkim)
where does the filter go??
Old Apr 1, 2002 | 03:34 PM
Default Re: Changing Fule Filter?? (integra81)
Passenger side firewall, right next to the battery.
Old Apr 1, 2002 | 03:38 PM
reefer_bob's Avatar
It is not a lifetime filter... 30k miles, 2 years... or if you run into some bad gas, and notice a lack of acceleration under WOT... That's alwasy a good place to start. Very easy to do.
Reefer_Bob.
Old Apr 1, 2002 | 03:42 PM
teg92's Avatar
I wonder if the honda engineers ever heard that sentance and chuckled at themselves...
[Modified by teg92, 7:42 PM 4/1/2002]
Old Apr 1, 2002 | 04:03 PM
six_speed's Avatar
Default Re: Changing Fule Filter?? (teg92)
so every honda/acura dealer sells them rite?
Old Apr 1, 2002 | 04:05 PM
poison's Avatar
Default Re: Changing Fule Filter?? (Lilmumbler)
ya, so does pepboys, autozone, checker and all those places >
Old Apr 1, 2002 | 05:29 PM
IntegraGSR23's Avatar
yeah no ****
Old Apr 1, 2002 | 05:32 PM
kkim's Avatar
must be... the first thing they say to do when changing the fuel filter is to disconnect the battery.
Old Apr 1, 2002 | 09:11 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Bah! just don't arc anything to the positive terminal of the battery and you'll be fine. There should be a cover over the pos. terminal anyway.
Old Apr 1, 2002 | 10:08 PM
teg92's Avatar
Default Re: Changing Fule Filter?? (PatrickGSR94)
It was just a passing joke!!
coronadrinker
Dec 18, 2006 05:58 PM
ddua
Sep 19, 2003 05:02 PM
CivilizedCiv
Aug 22, 2002 08:22 AM
sloaccord96
May 15, 2002 09:49 PM
