LS/Vtec or No?
Old Mar 26, 2002 | 05:52 AM
The Rob's Avatar
Default LS/Vtec or No?
I got a 93 Integra LS with a B18A1 in it. I can either go LS/Vtec with a b16A head, B16A1 (JDM) Cams, Etc. Or I can get Crower cams, Skunk2 Intake Manifold, Iceman Intake, DC 4-2-1 Header, etc. What setup should I have that would give me good power, but not cost a whole lot. BTW What else would I need if I wanted to put crower cams in my engine? How much would the cams run (roughly)?
Old Mar 26, 2002 | 05:59 AM
int3gra's Avatar
Default Re: LS/Vtec or No? (Zero_Effect)
dont go Crower, they break.
dont cheap out on the internals.........go TODA.
Old Mar 26, 2002 | 08:50 AM
6061's Avatar
ya go frankenstein FOR SURE, just don't go cheap on the internals.
Old Mar 26, 2002 | 08:56 AM
KraZyCHOWMEIN's Avatar
Default Re: LS/Vtec or No? (int3gra)
funny how skunk2's were breaking before also, crowers have fixed their problem just like skunk did.. so dont bad mouth it if u dont know whats really up, also every LS/Vtec that i have ever seen has eventually leaked oil..... so if u have an LS boost it, if u have a GSR boost that too, if thats too expensive then throw some ITR cams in ur vtec motor and give it a healthy dose of N20 and ur done.... if u go toda and the all motor route... just realize this ur gonna be spending A LOT of money..... the cams arent cheap, the valve train isnt cheap, then u have to swap out ur pistons cause wild cams dont like anything below 11.5:1 CR, the labor alone on ur block is gonna be over a grand..... think about it this way with all motor... u need all the pieces of the puzzle before you'll realize the full potential of waht you have just purchased... buying a set of Toda Spec B's and a junk2 manifold with a DC header will probably only net you about 170 whp......
think about the big picture, plan your steps wisely... and always look for bargins
Old Mar 26, 2002 | 09:15 AM
b18bvtec4drteg's Avatar
Default Re: LS/Vtec or No? (KraZyCHOWMEIN)
I havent had any oil leaks yet. (knock on wood) I have a braided line for the oil on the ls/vtec. However my rubber grommets on the valve cover are beginning to rot.. so there is some leakage.. Acura wants 4 bucks a piece!! What a gip!!
Old Mar 26, 2002 | 09:45 AM
The Rob's Avatar
Ok, I think am gonna not frankenstein. How much can I get crower camshafts+gears for online? How much work is it to install them?
thumper64
Feb 23, 2009 02:55 PM
redDAinteg
Aug 2, 2005 04:39 PM
kenepo_vtec
Jan 18, 2005 06:07 PM
keebler65
Feb 6, 2004 02:26 PM
ID_ten_T
Sep 16, 2003 08:07 PM
