type r header
Old Mar 24, 2002 | 04:16 PM
mrazian's Avatar
New User
Default type r header
will a stock type r header fit on a LS motor.
Old Mar 24, 2002 | 04:24 PM
Frito1's Avatar
Default Re: type r header (mrazian)
yes it will fit any b series motor
Old Mar 24, 2002 | 04:36 PM
LS Ass Ass In's Avatar
Default Re: type r header (tegsleeper)
except a 94-99 GSR
Old Mar 24, 2002 | 06:05 PM
nfn15037's Avatar
Default Re: type r header (LS *** *** In)
except a 94-99 GSR
Doubt that man, why is it i can put a JDM 4-1 on my GSR, which also happens to bolt up to a ITR head?
Old Mar 24, 2002 | 06:19 PM
IN VTEC's Avatar
Default Re: type r header (nfn15037)
because you got a new cat with it.
The primary bolt patterns are identical...it's the collector, cat, and b-pipe length that differ.
Old Mar 24, 2002 | 08:55 PM
blkbeast's Avatar
New User
would an ls benefit from a usdm itr header?
Old Mar 24, 2002 | 09:31 PM
Brandon Chun's Avatar
Default Re: type r header (blkbeast)
Yes it should bolt up, one of the brackets is too thick tho, so you can leave it off or use a longer bolt. Blkbeast I think it gives some midrange and top end, either way I got mine USDM for about 45 bucks.
Old Mar 25, 2002 | 06:31 AM
TurbothisLS's Avatar
Default Re: type r header (Brandon Chun)
Yes, a USDM will give you some gains in the mid-range. I have one on the LS and I can feel a definite difference. When you remove your LS header take a look at the difference in design between the two headers. The ITR header has longer 2 pipes that go to 1 and several other small differences that make big power differences.
Old Mar 25, 2002 | 07:58 AM
Mike K's Avatar
Default Re: type r header (TurbothisLS)
take the two pieces apart on the ITR header. port match them together, and give the upper portion of the manifold a rough polish with a die grinder.
this REALLY improves the OE exhaust manifold on the ITR..
not to start a flame war.. but I'll post this dyno to show you..
the motor is a b18c5 w/ 12:1 Endyn pistons, stock head, cam gears and tanabe exhaust.
red line is Toda Spec B's and Mugen 4-1 JDM header
blue line is Toda Spec A's and ported USDM ITR header
Old Mar 25, 2002 | 08:57 AM
harryg's Avatar
Default Re: type r header (Mike K)
I've got a question. I have a 95 b18b1, the O2 sensor is after the header. If I bought a Type R header, it'd obviously be OBD2 and would have the bung for the O2 sensor right on the header itself. Would I have to weld it shut or something like that?
Old Mar 25, 2002 | 02:39 PM
harryg's Avatar
Default Re: type r header (harrytg)
Eh? Anyone?
Old Mar 25, 2002 | 04:19 PM
slowerthanu's Avatar
New User
You can purchase a nut for the 02 bung, it will merely screw in, most shops carry it.
Old Mar 25, 2002 | 04:46 PM
harryg's Avatar
Default Re: type r header (slowerthanu)
Ahhh.. I see. Thanks for the info.
ubreak_ubuy
May 17, 2005 05:47 PM
Johnny62
Sep 27, 2002 06:39 PM
ILOVEGIRLS
Sep 17, 2002 11:57 AM
98R-1144
Aug 7, 2002 09:58 AM
