Header Flange Rusting?
Old Jun 3, 2002 | 09:39 AM
White Lightnin's Avatar
Default Header Flange Rusting?
I have a JDM 4-1 on my car and the flange is starting to rust. I plan on taking the header off while I am redoing my suspensions, gutting my A/C, and swapping in brakes. What can I do to stop the rust, and has anyone else had this problem?
Old Jun 3, 2002 | 12:07 PM
Default Re: Header Flange Rusting? (White Lightnin)
top
Old Jun 3, 2002 | 01:18 PM
IN VTEC's Avatar
My DC header's flange started rusting the next day after it rained. I'm not sure what you can about removing the surface rust, but I never cared to do anything about it.
Old Jun 3, 2002 | 01:20 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Header Flange Rusting? (IN VTEC)
You could use a dremel tool and some polishing pads to polish the rust off and then spray the header with high temp engine enamel.... aluminum colored would compliment your engine bay quite nicely. Spray the entire header though, not just a spot here and there. Be sure not to scratch the paint while installing it or after installation or it will just rust again. good luck
jksmith
Mar 2, 2009 06:47 PM
BIGTUNA
Welding / Fabrication
Apr 21, 2008 04:07 AM
category5 SI
Oct 21, 2007 12:41 PM
bootlegtrader
Aug 15, 2005 07:42 AM
Norcalstoppy
Nov 20, 2002 01:00 PM
