Question about Legality of Swaping Engines
Old Jun 5, 2002 | 11:32 AM
97integraLST's Avatar
Default Question about Legality of Swaping Engines
I am planning on getting probably a 91-93 LS.
Probably going to drop a GSR or what ever.
What are the legal issues of doing a swap?
Thanks in advance.
Old Jun 5, 2002 | 11:33 AM
mattL's Avatar
Default Re: Question about Legality of Swaping Engines (97integraLST)
just run the Vin and make sure the engine's legit, buying it from a reputable place is a good way to prevent that. Otherwise i'm not aware of any other illegalities
Old Jun 5, 2002 | 11:35 AM
Default Re: Question about Legality of Swaping Engines (mattL)
How about inspections? will it pass
Old Jun 5, 2002 | 12:03 PM
Cramerox's Avatar
well in california you have to take it to the state ref. then there they will inspect your car- and i mean inspect. you have to also remember that the motor you put it has to be newer than your car. also have the papers for the new engine.(ownership)
Old Jun 5, 2002 | 12:18 PM
erniecars's Avatar
Default Re: Question about Legality of Swaping Engines (Cramerox)
ive never heard that you had to take it to anyone for inspection. all you have to do is pass a regular smog check unless you get caught with a test pipe or something majorly illegal
Old Jun 5, 2002 | 03:11 PM
Halo's Avatar
Default Re: Question about Legality of Swaping Engines (erniecars)
Yes cramerox is right, anytime you install a motor that wasn't designed for that specific year/model it must go to the state ref. If your car passes hboth the visual and smog then you will recieve a BAR sticker. Without this sticker you risk getting your car impounded by a bitter cop or worse the carb
Old Jun 5, 2002 | 04:21 PM
uNF$@#!'s Avatar
Default Re: Question about Legality of Swaping Engines (Halo)
if you replace an engine, the engine must be from a car of same year or newer.
speedaholic92
226
Oct 21, 2011 10:50 AM
slo_ej8
Oct 28, 2007 05:19 PM
delslowhonda
May 2, 2006 10:52 PM
HybridIntegra
29
Sep 9, 2004 08:01 AM
SimbaDogg
Jan 31, 2004 03:01 AM
