testing shocks
Old Jun 4, 2002 | 10:19 AM
Integra187's Avatar
Default testing shocks
Recently i just installed some ground control coilovers and some koni shocks. The rear of my car seems to be real boucny enough to start hurting my back. I wanted to know if there is any way i could test the shocks to see if they are in good condition. They were purchased new.
[Modified by Integra187, 7:22 PM 6/4/2002]
Old Jun 4, 2002 | 11:30 AM
Ri5e's Avatar
Default Re: testing shocks (Integra187)
You might be just riding on the springs if the shocks are blown. What u can do is jack the rear up, take off hte tire. Lift the LCA up and down and look at the shock piston. If it seems to "stick" then its blown.
Old Jun 4, 2002 | 12:02 PM
BSQ's Avatar
BSQ
-What is the spring rate of your GCs (front and rear)? It is possible that you are using to stiff of a spring rate and Konis cannot dampen the GCs properly.
-How low do you have your GCs set? It is possible that you have them set to low and the Konis do not have enough travel to dampen the GCs properly.
-Did you reuse the stock bumper stops? If so, did you cut the bumper stops in half? If you reused the stock bumper stops but didn't cut them in half, it is possible that you are riding on the bumper stops and therefore the shocks cannot dampen the springs.
jdm13733
Honda S2000
18
Jan 29, 2011 07:54 AM
g5r
Suspension & Brakes
Mar 17, 2007 09:49 PM
CTR-GSR
Suspension & Brakes
19
Jan 10, 2006 07:19 PM
Toretto
Feb 18, 2004 06:40 PM
1fastGSR
Jul 30, 2001 07:21 AM
