Engine Sputters????
Old Jun 2, 2002 | 11:10 AM
formervendor's Avatar
Banned
Default Engine Sputters????
I have a 2nd Gen Integra w/ a B16A Swap, the car is strong running and is throwing no codes, but as you drive at any steady speed it kinda sputters or surges....if you push the pedal a little more it breaks free and accelerates. Whats up with that?? Help please it's very anoying.
Old Jun 2, 2002 | 01:21 PM
95gsr's Avatar
Default Re: Engine Sputters???? (Duckiller00)
is it when your in vtec? does it have oil?
Old Jun 3, 2002 | 05:27 PM
Banned
Default Re: Engine Sputters???? (95gsr)
It does it at different times. Yes, I have oil.
Old Jun 3, 2002 | 05:46 PM
mikecel79's Avatar
How are the plugs looking? Does it blow any black smoke when it sputters? What about the plug wires?
Old Jun 3, 2002 | 08:03 PM
Banned
Default Re: Engine Sputters???? (mikecel79)
New cap, rotor, ZFR5F11 NGK plugs, Magnacore wires, fuel filter, AEM fuel rail, AEM regulator, PCV valve, and stock injectors balanced and blue printed by RC.
Has any one had problems with the JDM PR3 ECU??
Old Nov 15, 2006 | 09:41 AM
Legend_master's Avatar
I am having the same problem on an obd-1 LS/vtec. It occurs between 2.5K and up when I try to maintain a constant speed. If I press on the gas to accelerate then the problem goes away. I replaced the distributor, plugs, wires, fuel pump, and FPR. I ran a fuel system cleaner and this did nothing. The problem seems to happen worse when it it cold outside. If anybody has any in-site please help. I occasionally get a code 43, but it only pops up every once in awhile.
Modified by Legend_master at 4:16 PM 11/15/2006
Old Nov 15, 2006 | 09:50 AM
yee SERIOUS's Avatar
check your fuel filter.
Old Nov 15, 2006 | 10:21 AM
Sumslapper's Avatar
Year 3030
Default Re: (undercoverdc2)
yes it could be your fuel filter and it also might be the ign. coil in the distributor
Old Nov 15, 2006 | 10:47 AM
aaronISthrowed's Avatar
Default Re: (sumslapper)
You switch gas or gas stations lately? Happened to my friend when he went to a different gas station. (well at least its what sounds like whats happening)
Old Nov 15, 2006 | 12:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">check your fuel filter.</TD></TR></TABLE>
Thats my next step,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sumslapper &raquo;</TD></TR><TR><TD CLASS="quote">yes it could be your fuel filter and it also might be the ign. coil in the distributor</TD></TR></TABLE>
I changed the whole distributor dident fix it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">You switch gas or gas stations lately? Happened to my friend when he went to a different gas station. (well at least its what sounds like whats happening)</TD></TR></TABLE>
same gas station I have always used. Use premium everytime.
Old Nov 15, 2006 | 12:43 PM
1RMDave's Avatar
POSSIBLY LOSING SPARK; SPRAY SOME WATER ON THE WIRES AND DISTRIBUTOR AND SEE IF THE SPARK GETS GROUNDED OUT.
Old Nov 15, 2006 | 03:16 PM
Default Re: Engine Sputters???? (1RMDave)
nope not losing spark, I checked that.
Old Nov 15, 2006 | 07:46 PM
eh2..765's Avatar
Default Re: Engine Sputters???? (Legend_master)
same problem here very annoying
Old Nov 15, 2006 | 07:52 PM
Default Re: Engine Sputters???? (teggy765)
Replaced Map sensor today, that is not the problem either. I ceaned out the valve on the back of the IM and restarted the ECU. THis seemed to clear up the problem, but that is what happens then it comes back after some driving. We will see tommarow.
90IntegraTuner
Apr 20, 2009 07:52 PM
asiansgoweeee
Jul 14, 2004 08:26 AM
Cyber ITR
Apr 2, 2004 11:23 PM
Revline
Jan 14, 2003 06:23 AM
