thinking of new engine mods to do...suggestion?
Old Jun 4, 2002 | 04:48 PM
SlyGSR's Avatar
Default thinking of new engine mods to do...suggestion?
Hi all, I've done the full suspension setup/tire mods and wanna go back to revisit the engine bay
So far I only have AEM CAI, new plugs, wires. I was thinking of Cam Gears or a Fuel Pressure Regulator...do these make any noticeable difference? what's next without going induction or turbo (well not yet anyways)
Thanks
SlyGSR
'98 GSR, AEM CAI, KYB AGX, H&R OE, Toyo T-1S, Brembo X-Drilled Rotors, Type R Strut Bar & Rear Tower Bar, 22mm sway bar
Old Jun 4, 2002 | 05:16 PM
sutrusu's Avatar
Default Re: thinking of new engine mods to do...suggestion? (SlyGSR)
get some cams foo
Old Jun 4, 2002 | 05:35 PM
StyleTEG's Avatar
Default Re: thinking of new engine mods to do...suggestion? (sutrusu)
I would get a good H/C/E setup before you get cams & cams gears. Otherwise you will probably need to retune them for peak performance once you get h/c/e, and dyno time is expensive.
Old Jun 4, 2002 | 06:18 PM
One20Two's Avatar
Default Re: thinking of new engine mods to do...suggestion? (StyleTEG)
Def Cams, or a built head if you have the loot. As long as everything is set up right, you can put off Dyno tuning until you get the header, Exh, etc.
Even a Throttle body, or Skunk Manifold.
I dont know jack about Cam Gear settings, so I have no insight there, sorry dude
Old Jun 4, 2002 | 07:20 PM
KamikazeRacinz's Avatar
you should get some CAMS.....good upgrade...!!!much better than bolt on's!!!!
Old Jun 4, 2002 | 08:29 PM
Isaac's Avatar
New User
Default Re: thinking of new engine mods to do...suggestion? (KamikazeRacinz)
Work on your bolt-on's before you go further, because they will compliment your cams. Get a nice JDM or 2.5" header (JDM ITR/JDM DC, Spoon, Mugen, Hytech, etc.) and a 2.5" exhaust system. Once you have the basics you'll be ready for cams, but get the basics down before you proceed.
Old Jun 4, 2002 | 08:35 PM
smeister's Avatar
Default Re: thinking of new engine mods to do...suggestion? (Waxing "The Carrot")
Well it all depends...if you want to go FI than just save up for that. If you plan on going NA then I would suggest a 2.5 inch exhaust system with a JDM header. Then I would go with the fpr and gauge, and cam gears, then cams, then vafc and tuning. Unless you want a more serious NA setup.
[Modified by smeister, 9:35 PM 6/4/2002]
[Modified by smeister, 9:36 PM 6/4/2002]
TegLK
Engine Machining & Assembly
Mar 7, 2018 07:30 PM
StreetRac3r
Jun 7, 2007 09:12 AM
gearhead18
Apr 5, 2003 11:04 AM
fast[R]
May 28, 2002 02:35 PM
Anthony K
Aug 28, 2001 09:48 AM
