JDM conversion Hood Latch Problem
Old Mar 22, 2004 | 11:04 AM
Uneekpinoysk8er's Avatar
Default JDM conversion Hood Latch Problem
well i went to go check up on my JDM front end conversion at the body shop, and i found outt hey ran into a problem. They said that the cable for the hood latch was too short and wouldnt reach the latch. Any solutions to this???? and heres a pic of the car.
Old Mar 22, 2004 | 11:12 AM
94mugenintegra's Avatar
Default Re: JDM conversion Hood Latch Problem (Uneekpinoysk8er)
90-93 integra cable will work
Old Mar 22, 2004 | 11:26 AM
Default Re: JDM conversion Hood Latch Problem (94mugenintegra)
are those the only cables that would work? are their any other car models that might work? or better yet, does any one know the part# so i can just pick one up at the acura dealer.
Old Mar 22, 2004 | 11:49 AM
Rory Breaker's Avatar
90-93 integra cable will do the trick.
You can have them flip the stock latch around as well.
Old Mar 22, 2004 | 11:54 AM
JDMjames's Avatar
I used the search function to find which one i needed...
J/K i'm not gonna pull that ****...
90-93 integ hood latch wire is what I used with flipping the stock latch works perfect. I also heard the 90-93 accord works too... if you can get the latch assembly from the 90-93 integ or accord it should work as well.
Old Mar 22, 2004 | 01:36 PM
Default Re: JDM conversion Hood Latch Problem (JDMjames)
yea i was able to get a 90-93 integra cable, do i need hte latch assembly?? ahh my front end is starting to become a headache HAHAHA
Old Mar 22, 2004 | 01:56 PM
JDMjames's Avatar
you don't have to use the 90-93 latch assembly. you can use the one you have just flip it around. Its what I did on mine...
Good luck mang
Old Mar 22, 2004 | 02:58 PM
Danger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uneekpinoysk8er &raquo;</TD></TR><TR><TD CLASS="quote">yea i was able to get a 90-93 integra cable, do i need hte latch assembly?? ahh my front end is starting to become a headache HAHAHA</TD></TR></TABLE>
i think i have an extra 90-93 integra hoodltach in my garage . PM me your address and ill send it out to you
christ0pher
May 9, 2007 10:38 AM
sihatch19
Jul 31, 2004 09:40 PM
98itR484
Feb 23, 2004 07:10 PM
advanracing62
Jan 6, 2004 04:22 AM
JDMjames
Oct 29, 2003 09:10 PM
