CEL
Old Mar 21, 2004 | 11:44 AM
Tulo's Avatar
Default CEL
I have a 99 GSR. Whenever I drive it really hard(red-lining etc.) the check engine light will come on. At that point it tends to run like crap. My air/fuel gauge will read rich instead of bouncing back and forth like normal. The idle also raises up and the car just doesn't run good. It runs like this until I turn the car off and restart it. How can I make this go away? BTW, I have i/h/e, and a v-afc. Thanks for any help you can give.
Old Mar 21, 2004 | 12:45 PM
Kendall's Avatar
Have it checked to see which codes it's throwing, and then you'll have something to go by.
Old Mar 21, 2004 | 01:09 PM
Tulo's Avatar
Default Re: (Kendall)
P1298 - Manaf air/fuel meeting
P0108B - Map/Baro Circuit Highlight (<--my handwriting got illegible there,sp?)
Old Mar 21, 2004 | 02:15 PM
SuzukaBlueAP2's Avatar
Default Re: (Tulo)
Code P1298 has nothing to do with manifold air/fuel meeting. I don't know where you got that from. Hope these help.
P1298 is Electrical Load Detector Circuit High Input. (ELD)
P0108 is Manifold Absolute Pressure High Input
Old Mar 22, 2004 | 07:30 AM
JimBlake's Avatar
Default Re: (Tulo)
The codes with a first digit 0, like P0108, are supposed to be the same for all carmakers. Higher-# codes are different, so maybe P1298 means air/fuel for somebody other than Honda??
That's why I try to suggest if you go to AutoZone to get a code, get the code number. Good thing you did...
Tong.Y
May 16, 2011 03:52 PM
gsr converters
Sep 13, 2006 10:08 PM
2DXtreme
Apr 1, 2005 11:00 AM
shadowdawn
Oct 10, 2002 11:24 PM
