Power steering pump
Old Mar 23, 2004 | 09:56 PM
demon_TEG's Avatar
Default Power steering pump
HI there ppl, I had a quick swap + power steering pump question..ok I'm going to be swapping in a new motor in to my 92 LS..my question is..and this is what I'm think before I put the motor..in is that I noticed the Power steering mounting bolts are different on my ITR head..and on my LS head..like the Itr head the bolts are at a slight angle and on the LS head the power steering pump bracket mounting bolts are paralel..or like at the same height..now the thing is I wanted to know if I'm doing this swap..do I need a different power steering pump or is the bracket to hold the power steering pump up different and the pumps are the same?? If you guys get what I'm trying to get at then let me know what you think..like I'm worried that I have to change my brand new underdrive crank pulley as well as my aem pulleys..because of this stupid little problem..
Old Mar 24, 2004 | 12:41 AM
King_j's Avatar
Default Re: Power steering pump (demon_TEG)
if the old pump and bracket fit on the new motor, then you should have nothing to worry about.
is the pump in the way of the pulleys?
jdm 1080p
Sep 13, 2012 07:32 PM
khailon
May 7, 2011 10:49 AM
JussHatched
Apr 24, 2006 07:53 AM
