Da conversion
Old Mar 21, 2004 | 09:09 AM
SivARt's Avatar
Default Da conversion
i am looking to buy my sisters perfect 93da its perfect the only prob. is that its an automatic i plain on drouping a new engine in soon as i get the car just wanted to know how much dose the converson usually run and if anyone knows all the parts i need thanks
Old Mar 21, 2004 | 09:11 AM
Kendall's Avatar
Honestly, all the necessary parts should cost more than about $500. You can probably dig them all out of a junkyard.
Old Mar 22, 2004 | 08:18 PM
totalchaos's Avatar
Default Re: (Kendall)
if u wanna go cheap yeah. Me on the other hand, i've spent good money for my swap. 200 bucks on a exedy stage 2 clutch kit, 185 on a ACT flywheel, 320 for the transmission, 65 on a b&m short shifter, 16 on a type r shift ****, then i got a shift boot, pedals (25 from a friend), manual tranny mount, shift linkage (20 from a friend) and some other stuff, i can't remember.
Old Mar 22, 2004 | 08:27 PM
mr.beeks's Avatar
Default Re: (totalchaos)
not to brag but I just sold my whole conversion that
included:
tranny, pedals, cable, 5spd ecu, shift linkeage, used clutch kit, flywheel
for $500.
but if you try junkyards it will cost a little more
Old Mar 23, 2004 | 08:59 AM
hadehatch's Avatar
Default Re: (mr.beeks)
With the manual tranny mount you will still have to shim it or make a custom spacer since the mounting bracket is placed differently on the frame.
Or you can cut it out and reweld it.. either way its not plug and play..
Old Mar 23, 2004 | 09:34 AM
projectTeG's Avatar
i got all my parts from a junk yard for like 600. it was pretty simple but far from easy. it was time consuming and frustrating at times. as for the tranny mount all you need to do is go to a hardware store ( or a place that sells metric grade 8 bolts) and get 5 1/2 in. longer bols then to stock ones, then you have to get some nuts(spacers) that are 1/2 wide and use them to shim the mount up.
search on g2ic.com thats were i found all my swap info.
Old Mar 23, 2004 | 11:04 AM
SivARt's Avatar
Default Re: (projectTeG)
thanks for all the post peps.
jdmdb1integra
Jan 13, 2012 10:37 PM
jyacoba2009
Oct 6, 2009 11:27 PM
lude1888
Oct 6, 2005 09:06 AM
jspec - integra Ls
May 18, 2004 10:08 PM
4door93civic
Oct 29, 2003 09:58 AM
