code 8? help please
Old Mar 23, 2004 | 08:44 PM
E36 Guy's Avatar
Default code 8? help please
hey im throwing code 8 on my obd0 pr3 ecu. i have a b18c swap if that matters. i see its the TDC sensor, but my question is, where is that and how can i fix it. thanks!
Old Mar 24, 2004 | 03:55 AM
JimBlake's Avatar
Default Re: code 8? help please (b18c3)
It's in the distributor, one of the sensors around the shaft. Unless you find something easy like a loose wire or mounting bolt, you have to replace it. I've heard you can't get the sensors without buying the whole distributor(?)
Old Mar 24, 2004 | 10:10 AM
E36 Guy's Avatar
Default Re: code 8? help please (JimBlake)
damn! its wierd though, my check engine light isnt on, but my ecu still blinks 8 times. and i know my check engine light works so..
Old Mar 25, 2004 | 01:10 PM
E36 Guy's Avatar
bump
Old Mar 25, 2004 | 01:12 PM
JimBlake's Avatar
I don't know... Maybe it's stored from an earlier problem? Clear it to see if it comes back (did you already do that)??
Old Mar 25, 2004 | 05:47 PM
E36 Guy's Avatar
ill try that, thanks
rjdevita
Jun 13, 2006 04:16 AM
Airbag Club
11
Mar 10, 2005 03:05 PM
Sobe_Death
Mar 11, 2004 10:09 AM
TyPe-R6
Jun 18, 2003 03:41 AM
hb_racer
May 29, 2002 07:28 PM
