suspension setup
Old Mar 23, 2004 | 03:41 PM
Maxboost808's Avatar
Default suspension setup
I just finished having my supension setup for 92 integra installed but I still have two pieces left and im not sure what to get. For my swaybar im stuck between the suspension techniques or the progress bar. Am im also not sure weather to go for spc control arms or an ingalls camber kit. What are most of you guys using.
Old Mar 23, 2004 | 03:44 PM
civicbro's Avatar
Default Re: suspension setup (Maxboost808)
ingalls
Old Mar 23, 2004 | 04:34 PM
silvrintegra's Avatar
Default Re: suspension setup (civicbro)
As far as sway bar either would be fine. But, was wondering if you could mate a Type-R sway bar to the 92 instead cause that would be a good upgrade. As far as camber kit do you really need it. After lowering you should get an alignment unless they tell you that you have bad camber. Otherwise the alignment should fix it. Cause I'm gonna get mine aligned again cause I had to raise it for inspection but gonna lower it back so gonna get that done. But, camber kit I never bothered with.
Oh if anyone knows if the Type-r would fit that would be a good direction to lean towards.
jaygood2go
May 23, 2013 01:43 PM
therealeg6
Suspension & Brakes
16
Jul 8, 2009 02:18 PM
royalrebel
Nov 9, 2008 02:46 PM
The Si
Suspension & Brakes
Mar 12, 2007 11:29 PM
YelloEco
Jun 17, 2004 01:17 PM
