ECU PROBLEM?
Old Mar 22, 2004 | 08:15 AM
VTECPowerdSi's Avatar
Default ECU PROBLEM?
I recently did a swap on my 2000 civic si and put in a B18C JDM GS-R motor using my old B16A2 ECU, after about 6500RPM the car slows down considerably. I had a couple trannys put in as well as some gears swapped out when my tranny was having problems but i dont think it could be gear ratio's, i think its the ECU making it run lean or rich, if anyone has any ideas or suggestions please post, thank you.
Old Mar 22, 2004 | 08:41 AM
.M.'s Avatar
.M.
Default Re: ECU PROBLEM? (VTECPowerdSi)
chip ecu
Old Mar 22, 2004 | 10:43 AM
AllMotorGSR94's Avatar
Your using the b16a ECU on a GSR? The GSR has a dual stage intake manifold controlled by a secondary runner in the manifold. They are opened by the ecu. There is a sensor under the Intake manifold that controls this. If your using the GSR Manifold you have to use the GSR ECU or they wont open creating a restriction in air flow.
Old Mar 22, 2004 | 07:42 PM
Default Re: (AllMotorGSR94)
Thats what they tell me, i actually hooked up a p72 obd1 with a mugen chip today and it didnt help the long range after 6500 but the guy at the shop drove my car and said i had an ls tranny which has long gears so thats why it slows down after 6500rpm?
ef2hondaboi
Jun 23, 2009 04:33 PM
team 15
Jun 18, 2007 12:22 AM
silintegra
Aug 12, 2005 05:49 PM
u2civic1
Mar 10, 2003 04:59 AM
B19CivicHB
Jan 22, 2002 02:13 PM
