left blinker is blinking faster than right, help
Old May 3, 2004 | 09:20 AM
CrazyModGSR's Avatar
Default left blinker is blinking faster than right, help
Not sure what the problem is. My left blinker/turn signal is blinking about twice the speed of my right blinker/turn signal. What could be the problem? I actually like it blinking faster, so how might I change the right blinker to blink at the same speed as the left one?
Thanks
Old May 3, 2004 | 09:23 AM
OoCanibus1oO's Avatar
Default Re: left blinker is blinking faster than right, help (CrazyModGSR)
when it blinks, in the dash faster then normal usually means your light is out.
Old May 3, 2004 | 09:27 AM
Default Re: left blinker is blinking faster than right, help (OoCanibus1oO)
what light? it blinks at different speeds on the outside of the car too
Old May 3, 2004 | 09:28 AM
xplanetearth420x's Avatar
check if any lights are out
Old May 3, 2004 | 09:29 AM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyModGSR &raquo;</TD></TR><TR><TD CLASS="quote">what light? it blinks at different speeds on the outside of the car too</TD></TR></TABLE>
Yes, that means the bulb is out in your left blinker. It could be the rear, or the front bumper lenses. Note that the front bumper lenses have a dual filament bulb. Even if one of those filaments are busted, it will count as the entire bulb being out.
Old May 3, 2004 | 09:34 AM
boostmywankle's Avatar
Default Re: left blinker is blinking faster than right, help (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, that means the bulb is out in your left blinker. It could be the rear, or the front bumper lenses. Note that the front bumper lenses have a dual filament bulb. Even if one of those filaments are busted, it will count as the entire bulb being out. </TD></TR></TABLE>
Bingo...i agree 100% with him!
Old May 3, 2004 | 09:37 AM
grlstockb18c1's Avatar
super blinker means new bulb
Old May 3, 2004 | 09:48 AM
Default Re: left blinker is blinking faster than right, help (Grlsb18c12slow)
ok, that makes sense, because i believe my left front side marker is out. is there anyway to replace the bulb, but then make both blinkers blink fast. as i mentioned, i like it a little faster, and even the teg that i am selling now has always had fast blinkers (probably twice as fast as normal). does this depend on the relay?
Old May 3, 2004 | 08:39 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyModGSR &raquo;</TD></TR><TR><TD CLASS="quote">ok, that makes sense, because i believe my left front side marker is out. is there anyway to replace the bulb, but then make both blinkers blink fast. as i mentioned, i like it a little faster, and even the teg that i am selling now has always had fast blinkers (probably twice as fast as normal). does this depend on the relay?</TD></TR></TABLE>
Okay.....first....J00 are a ricer!
Anyway, to make then faster all the time, do this. Unscrew your corner lens in the front. Pull the assembly out from the bumper and you will see a wire harness go into the lens. There are 3 wires going into it, right? You want to switch the outer two wires.
To do this, remove the harness from the lens by twisting it and pulling out. Then remove the bulb. Then you can "push" out the wires from the inside and then swap out the outer two wires.
Note that this isn't perfectly "healthy" for the car, but it gives you that fast-blinker that you want. It will blink fast inside on the gauge cluster as well as outside on the actual blinkers.
Note again, that your front bumper lenses will now always have both filaments on all the time when your parking lights are on. So when you have your primary lights on, they will be brighter. When your primary lights are on AND your turn signals are on, they won't be very noticable since both filaments are already on. The might dim and get bright but that's it. Won't be as noticable as before.
This is the easy/free way to do this. The other way is to purchase a relay and do some extra wiring.
Old May 3, 2004 | 08:57 PM
hadehatch's Avatar
They sell some fast blinker relay crap on eBay that replaces your blinker relay and makes them blink fast.. I think its adjustable as well.. something along the lines of SUPER HYPER BINKER RACER MODULE!!!!!.. lol good luck with your project
Old May 3, 2004 | 09:22 PM
Default Re: left blinker is blinking faster than right, help (hadehatch)
thanks, and please lay off the rice bullshit. call me rice when i'm smoking you, lol. don't mean to start any ****, the word is just overused. i don't need unwanted comments, just asking for help. btw, many might consider your agressor front bumper rice
Old May 3, 2004 | 09:35 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyModGSR &raquo;</TD></TR><TR><TD CLASS="quote">thanks, and please lay off the rice bullshit. call me rice when i'm smoking you, lol. don't mean to start any ****, the word is just overused. i don't need unwanted comments, just asking for help. btw, many might consider your agressor front bumper rice</TD></TR></TABLE>
Heehee, I'm just messing around. I only had that bumper on for a short period of time. Then I swapped to a 98+ front end, and a built motor + turbo. No rice, y0!
Old May 3, 2004 | 09:42 PM
i just got my "new" '94 GSR w/ t3/t4 turbo, intercooler, the works - jdm front end - no rice here either (except for the fast blinking corners, single wiper, and possibly the wing, which actually looks better than a lot of other wings, but may remove eventually - not a priority)
Old May 3, 2004 | 10:02 PM
xteg95's Avatar
who's to say a car cant be fast and ricey
and i had my wiring for my parking/turn signal lights cut a month ago and it does that fast blinking ****....its the most annoying thing i have ever experienced, and i even feel dumb turning it on...i dont know how you could like that...but that just me
Old May 3, 2004 | 10:18 PM
EJ8 Kenobi's Avatar
Default Re: left blinker is blinking faster than right, help (xteg01)
cut the ground wire (black) on the turn signals to have super blinker speed...
Old May 3, 2004 | 10:26 PM
lkshs123's Avatar
Default Re: left blinker is blinking faster than right, help (FrankGSR)
Probably a fuse.
Old May 3, 2004 | 11:01 PM
r0c5t4r's Avatar
Happened with me, it means one of your light bulbs aren't working.
Old May 4, 2004 | 04:31 AM
sleepin91teg's Avatar
Change the bulb on the right side...its gonna burn out...
Old May 4, 2004 | 04:59 AM
nyo91's Avatar
Default Re: left blinker is blinking faster than right, help (sleepin91teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xplanetearth420x &raquo;</TD></TR><TR><TD CLASS="quote">check if any lights are out</TD></TR></TABLE>
Old May 10, 2004 | 10:26 PM
bleeedawg's Avatar
Make note though***having faster blinkers are illegal. i had friends getting pulled over before and got cited for having fast blinkers.
Old May 10, 2004 | 10:31 PM
Default Re: left blinker is blinking faster than right, help (bleeedawg)
i know it is illegal, but honestly i don't think cops around here nit-pick about stuff like that too much. i bet CA cops are up on the automotive laws, whereas not so much (i don't think at least) in CT
Old May 10, 2004 | 10:32 PM
Kusai.Nihonjin.Desu's Avatar
Come'. Gohan. Shiro. Vroooom. *take off*
D7_62
Jun 20, 2010 05:53 PM
acura1masco
Acura TL, RL & ZDX
Jun 7, 2007 08:32 PM
g2b2
16
Jun 6, 2007 12:46 AM
mrjaydem
Sep 18, 2005 07:35 PM
vertius
May 11, 2002 12:15 PM
