comptech gsr filter
Old May 3, 2004 | 06:18 PM
Transport's Avatar
Default comptech gsr filter
will the replacement cone filter fit with my stock gsr box?
Old May 3, 2004 | 07:11 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: comptech gsr filter (Gr8GrZ)
Yes, it should. I had one until I replaced the OEM box with the Ice Box. You reuse the rubber gasket and the rubber tip on the end of the OEM filter. So don't toss your old filter until you get these parts off of it, per the Comptech instructions. (which you can download off the Comptech website)
Old May 3, 2004 | 07:56 PM
Transport's Avatar
Default Re: comptech gsr filter (Gee3)
thanks, gasket meaning the rubber that is use to hold the box and filter together?
Old May 4, 2004 | 08:00 PM
Gee3's Avatar
There's a large round rubber gasket on the end of the OE filter. The part that connects to the intkake arm. It is used as a seal for the intake box around the large neck area on the end of the filter [that goes to the intake arm].
Sorry for the late reply. I've been swamped at work and I can't post at work. Read only! Crap!
Good luck!
Old May 4, 2004 | 09:34 PM
Transport's Avatar
thanks
Honda.F1
May 15, 2004 03:27 PM
wizzards581
Apr 3, 2004 10:46 AM
EricUSC
Jun 8, 2003 08:48 PM
zk11
Dec 4, 2001 12:22 PM
