VAFC problems
Old May 1, 2004 | 04:22 PM
tegon-gsr's Avatar
Default VAFC problems
ok i have gone through with this every board that talk about this problem and on here a few times i have read about it for a while and done diffrent things to try to fix this problem. Im still throwing a code 22 i have change my vtec switch i have check the wiring and check my oil levels the only thing i can think of is.
A. maybe it has to do with my oil filter i herd that acura makes special filters that heat up or are smaller something like that.
B. my vafc controller is not hook up right even though i check it about 4 times or maybe i need to un hook it and re connect it?
If there is anyone out there with a apex vafc that has this problem and fix it please let me know how you did it.
the symptoms im having is that the check light wont come on unless im on the high way in around 3 or 4th gear in vtec other then that it generally does not come on.
Old May 1, 2004 | 05:33 PM
95 integra's Avatar
Default Re: VAFC problems (tegon-gsr)
whats code 22, for those of us too lazy to look it up
Old May 1, 2004 | 05:52 PM
b16hybridsol's Avatar
Default Re: VAFC problems (95 integra)
vtec press. 20 bucks says its wired wrong
Old May 1, 2004 | 06:29 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: VAFC problems (b16hybridsol)
what year is your ECU?
My buddy had the same exact problem. He didn't hook up the VTM wire cuz the directions on the Apexi instruction book didn't show it. But you need to! We are both running 98'-99' OBD2a ecu's. Apexi-usa.com has an updated manual on their site showing that this terminal needs to be connected. Go to Documentation/VAFC update and I used diagram WH-2. I just matched my ECU with their diagram to determine which diagram to use because they show '99's as WH-3 but my ECU is not obd2b. Either way, this update shows you where the VTM signal is no matter what ECU you are running.
If you are running the same ecu as me it's terminal 15 on terminal connector 31p, I believe the center connector. (my friend has my Helms) It's a blue/black wire, the vtec pressure switch. Page 11-40 in the '98-99 Helms manual.
Good luck!
Old May 1, 2004 | 10:10 PM
tegon-gsr's Avatar
Default Re: VAFC problems (Gee3)
i wired up all the wires at first i didnt think it i had to then i check teh update and then i wire the vtm wire but im still having this problem does anyone have a pic of there harn for a 0bd1 95 gsr maybe i wire it wrong but i doubt it
Old May 1, 2004 | 10:50 PM
ChopstiX's Avatar
which end of the VTM wire did you hook up.. your suppose to connect it to the end of the wire coming out of the ecu plug then the other half of the wire just tape it off..
Old May 2, 2004 | 05:15 AM
tegon-gsr's Avatar
Default Re: (ChopstiX)
can you get into more detail what you mean by this i might have messed up the the way your explaining it if so can you get a pix thanks
Old May 2, 2004 | 06:27 AM
Default Re: (tegon-gsr)
blue wire
1999CivicSi
Sep 24, 2005 12:00 PM
Superman137
Jun 24, 2005 08:48 AM
Superman137
Jun 24, 2005 08:46 AM
pushin redline 6
Mar 5, 2002 07:20 PM
