need help installing cams
Old May 3, 2004 | 07:13 PM
williamdte's Avatar
Default need help installing cams
can anyone help me out about installing cams. do you just bolt on the cam gears and put the timing belt back on and lay them in there?
Old May 3, 2004 | 07:16 PM
VTECorona's Avatar
Default Re: need help installing cams (williamdte)
By the way you said that I would get a mechanic that knows what he is doing. Screwing up a cam install can be very pricey.
If you feel confident that you can do it, get a Helms shop manual before starting.
Old May 3, 2004 | 07:24 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: need help installing cams (VTECorona)
Unless you have someone that knows what they are doing to help you out, it may be a better idea to get it done professionally. It's simple, but that's for people that have done it before. Plus, you may want to get a Helms manual too if you plan on working on your own car. The Helms manual is the bible!
FYI: Here's an article on cam installs so you know what to expect: http://tech.hybridgarage.com/tech/cams.html
SrT4u2nV
Dec 3, 2005 07:28 PM
ITRfaithful
Feb 19, 2003 04:07 AM
dubbb ls
Feb 12, 2003 11:31 AM
Nate B
Oct 18, 2002 08:39 AM
