Ground Controls?
Old May 1, 2004 | 05:05 PM
InTegraLS_2001's Avatar
Default Ground Controls?
Does Anyone know the diffrence between Ground Control Limited Editions and Regular Ground Controls? Thanks
Old May 1, 2004 | 05:19 PM
slowacura's Avatar
Default Re: Ground Controls? (InTegraLS_2001)
i think limited editioins were made in mass production to fit a bunch of cars and thus they are cheaper. regular GC's are specific for each car. that's what i heard...
Old May 1, 2004 | 05:34 PM
Muckman's Avatar
Moderator in Chief
Default Re: Ground Controls? (inteGSR)
correct.
Old May 1, 2004 | 05:39 PM
blitzteggsr's Avatar
limited ground controls can adjust from 0" - 3.5" where as normal ground controls adjust from 1" - 4". Correct me if i'm wrong.
Old May 4, 2004 | 09:33 AM
Phatch99's Avatar
Default Re: (blitzteggsr)
Do they still ride the same? If so, wouldn't everybody be buying those instead of the more expensive ones?
Old May 4, 2004 | 09:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I always thought the Limited Edition ones were a lower spring rate to make it more "streetable" or whatever... I don't really care, I'm going to be ordering custom spring rates to go on the special new Koni-specific GC sleeves that cover the whole shock body.
Old May 4, 2004 | 09:49 AM
Phatch99's Avatar
Default Re: Ground Controls? (PatrickGSR94)
So the limited edition ones would be better for street? I just want to know if they really ride the same cause i was thinking about ordering a set but still debating if i should get the limited ones or the reg. ones which cost a little more. I was just planning on droping the car like 2".
Old May 4, 2004 | 12:29 PM
Phatch99's Avatar
Default Re: Ground Controls? (Phatch99)
Anyone?
Old May 4, 2004 | 01:48 PM
tub_sephiroth's Avatar
The regular ones, you can choose custom spring rates. The Limited Editions are fine.
Old May 4, 2004 | 02:22 PM
SonicBlueTeg's Avatar
Default Re: Ground Controls? (tub_sephiroth)
http://www.ground-control.com
i've got gc's n' konis.. 380F 500R i love em.. the fact that u dont have to wait months and months for the boats to come in just to swap spring rates is definitely a convenience...
Old May 4, 2004 | 03:57 PM
patmcd's Avatar
Default Re: Ground Controls? (SonicBlueTeg)
the 500 lb rear is custom i assume?
Old May 4, 2004 | 04:27 PM
andrew dc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I always thought the Limited Edition ones were a lower spring rate to make it more "streetable" or whatever... </TD></TR></TABLE>
exactly. The ones made for the dc are 350/280 and i know the limited edition is softer than the dc rates... all it is, is a lowering spring... not something you want to take to the track or handle turns at a high rate of speed at.
cvjoint
Feb 23, 2008 06:25 PM
BrandonClaps
Nov 7, 2003 10:36 PM
LillDragun
Jul 24, 2003 02:36 PM
Understeer
Jan 22, 2003 02:24 PM
edz92tegrs
Feb 27, 2002 10:35 PM
