Engine Running Temp
Old May 3, 2004 | 10:21 AM
jdecks23's Avatar
Default Engine Running Temp
Hey all, I just joined, I usually spend all my time at G2ic and just come over here to do alot of searching. But I finally decided to register. Well i searched and couldn't exactly find a definite answer to my latest question. Well my car runs at a steady 200 in the winter (because the heat is on) and now that its spring I've noticed that my car runs a steady 207-210. Is this okay because I am stressing about it?
Old May 3, 2004 | 11:07 AM
IntEGNYC's Avatar
Default Re: Engine Running Temp (jdecks23)
your car generally runs cooler because of the outside temperature and warmer when the seasons warm up. As long as youre not idling near the red zone of the thermostat, you should be fine.
Old May 3, 2004 | 11:49 AM
jdecks23's Avatar
Default Re: Engine Running Temp (IntEGNYC)
Well I'm using an aftermarket guage, So if I'm running at 210 its okay?
Old May 3, 2004 | 12:49 PM
boost fed ls's Avatar
when my integra hits 210, the fan kicks on and brings it back to around 150-180.
Old May 3, 2004 | 01:07 PM
turbotommy's Avatar
Default Re: Engine Running Temp (boost fed ls)
i have a pwr 1/2 radiator and i run 210 coming out of the eng and 180 going back in. ****...i live in az and my fan doesnt really kick on that often.
Old May 3, 2004 | 01:38 PM
IN VTEC's Avatar
My car usually runs at 180 to 185 deg Fahrenheit while driving, and gets up to 190 to 195 if I let it heat soak during lots of stop-n-go driving or if the ambient air temps are greater than 80 deg F while highway driving.
I don't have AC anymore, so the condensor is gone and I'm also using a little bit of Redline Water Wetter.
Edit: I should note that all the readings were taken from the ECT sensor on the side of the head and logged using Hondata.
Also, the only time I've gotten the coolant temps above 200 is during dyno load tuning. I'm sure it'll be close to the same thing if I'm on a road course.
Modified by IN VTEC at 8:16 PM 5/3/2004
Old May 3, 2004 | 01:47 PM
jdecks23's Avatar
My fan does come on and my entire cooling system is working fine, and like i said my cars stays around 207-210 pretty much all the time in the summer etc, is something wrong or am I just paranoid because I am looking at numbers instead just a needle?
Old May 3, 2004 | 04:30 PM
turbotommy's Avatar
thats normal i believe...
Old May 4, 2004 | 10:59 AM
jdecks23's Avatar
Default Re: Engine Running Temp (turbotommy)
thanks, yeah im pretty sure it is, i just wanetd to check because I wasn't sure if i should be worrying or not
Old May 4, 2004 | 12:13 PM
whoisbrandon's Avatar
any comments on aftermarket therma stats?
Old May 4, 2004 | 01:23 PM
jdecks23's Avatar
Default Re: (whoisbrandon)
what exactly do you mean?
Yeret
Sep 12, 2014 04:46 AM
b20bFourDoorCivicLX
Jan 12, 2012 09:39 PM
jeremyrocksursox
Jul 15, 2009 05:58 AM
the.hamburglar
Jun 15, 2008 11:27 AM
