shock bolt?
Old Apr 29, 2004 | 06:04 PM
Liquidgsr's Avatar
Default shock bolt?
My shock bolt is seized in the rear. I need to get a new one and i went to the dealer to pick two up, but they charge $10 a bolt. I also went to fishers hardware and got a bolt that works, but my question is will this bolt hold up the pressure from the shock or do i have to use the one from the dealer? I wouldn't want the bolt snapping and the shock falling off of the LCA.
Old Apr 29, 2004 | 06:09 PM
Kendall's Avatar
Just make sure that the bolt you got is of an equal or higher grade and you won't have a problem. My car is full of bolts from Hardware stores, auto parts stores, and Home Depot.
Old Apr 29, 2004 | 06:43 PM
Liquidgsr's Avatar
Default Re: shock bolt? (Liquidgsr)
anyone know what the grade is...this bolt has a 3f and 8 written on it. anyone know what the stock on has on it or what not.
Old Apr 30, 2004 | 07:24 AM
foxfai's Avatar
The bolt at the normal hardware store WON'T work. i went to home depot and ask those people that work there and they don't have anything close to the one dealer has. MAKE SURE YOU USE GRADE 8 OR HIGHER OR STEEL HARDENED BOLT. Or else your car might be busted down the road.
Old Apr 30, 2004 | 07:27 AM
gundamgsr's Avatar
if you have doubt, its probably not a good idea.
i always get dealer quality or better. because i drive with my life and my girl's
Old Apr 30, 2004 | 12:18 PM
Liquidgsr's Avatar
Default Re: (gundamgsr)
anyone know of anywhere i can get these online for cheaper. 10 bucks per bolt seems a little too steep for me.
Old Apr 30, 2004 | 12:25 PM
MightyMouseTech's Avatar
Default Re: (Liquidgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquidgsr &raquo;</TD></TR><TR><TD CLASS="quote">anyone know of anywhere i can get these online for cheaper. 10 bucks per bolt seems a little too steep for me.</TD></TR></TABLE>
Then save your cash and wait until you can afford the real bolt from the dealer. You are probably going to need the bushings as well as it is usually the bolt seizing in the bushing which needs to be torched out.
Old Apr 30, 2004 | 12:27 PM
Liquidgsr's Avatar
Default Re: (MightyMouseTech)
actually i have brand new rear lower control arms, so no i don't need new bushings. i just don't want to pay 80 dollars for a couple bolts.
Old Apr 30, 2004 | 01:57 PM
Jasper_db1's Avatar
False economy
Old Apr 30, 2004 | 04:36 PM
gundamgsr's Avatar
if you want to cut corners on your ride, this probably isnt the best place to ask. we love our tegs. sorry.
try the civic forum they can help.
Old Apr 30, 2004 | 07:00 PM
Liquidgsr's Avatar
dude im not cutting corners. I just asked if i could find this bolt for cheaper. I didn't ask anything else. One person gave me an answer saying what kind of bolt I need. With that the question was answerd. Ill go to the dealer on monday and order the two bolts i need for the back and the one front bolt i need. Thanks for the help. To let you know i have not cut any corners thus far. Everything i have put on my car is good parts. Shocks are KYB AGX shocks, GC coilovers, Spoon lower tie bar, Spoon rear strut bar, and nar-spec LCAs. I just don't want to be ripped off by the dealer thats all. Just wanted to see if there was any other bolt just as good as the dealer that i could get for cheaper. So im done...thanks for the help. Ill just order them from the dealer.
Old Apr 30, 2004 | 07:07 PM
SwedBoy2999's Avatar
I totaly agree.... it's not work saving pennies over a bolt that holds up your suspention... but i think it's worth the money to go to the dealer or if you live in washington on the west side to go to U-Fix it Honda and i get bolts for free from there. I ride with my girl too it's not worth taking that risk.
Old May 1, 2004 | 01:02 AM
gundamgsr's Avatar
if you can spen 10 times the amount of an ebay rear strut bar for a spoon one, than why cant you buy an oem bolt ?
Old May 1, 2004 | 06:58 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
acuraautomotiveparts.org has the bolt for $7.33.
I remember when I first installed my shocks, I was afraid I might break my bolts, so I bought some grade 8 metric bolts of proper length and washers from Pep Boys, but I ended up not needing them because my stock bolts are still good.
*edit* actually what I got was grade 10.9 bolts, which is pretty much one of the strongest bolts you can buy.
Old May 1, 2004 | 09:11 AM
Liquidgsr's Avatar
Default Re: (PatrickGSR94)
haha im just kidding about the spoon stuff. I have generic ones. yeah i found the acura automotive site. I am going to order them all off of there since i can have it shipped straight to my house. I wont worry about driving so far to the acura dealer. Thanks peoplez. oh and i didn't know where to get high grade bolts also. i bought some bolts that fit but i don't trust them so imma spend the dough and drop my car..WISH ME LUCK PEOPLE.
Old May 2, 2004 | 07:47 PM
gundamgsr's Avatar
post a pic when your done
Old May 2, 2004 | 07:51 PM
Liquidgsr's Avatar
ok well i orderd them friday should be here before wednesday...finals are done then ill have the car on some jacks and working on them then...i just need to find a place that can take the front fork bolt out and if the bushign gets messed up i also orderd a new one of those. Hopefully though by thursday ill have a picture of it slammed.
Old May 15, 2004 | 03:58 PM
Liquidgsr's Avatar
Its done finally. After a 3 year wait its done. My car is the biggest biotch in the world and a worst nightmare, but its done. Ill post pics as soon as possible.
Old May 15, 2004 | 04:03 PM
oMek's Avatar
i just bought all new lca/shock bolts from honda for 60$.
then i wint to advanced autoparts and they had the same bolt (almost) for 2$
the lower shock bolt is a "m10 1.25" im not sure how long it is?
Old May 17, 2004 | 06:05 AM
Liquidgsr's Avatar
Default Re: shock bolt? (oMekoneDC2)
The aftermath...
KKRIS
27
Feb 28, 2012 09:21 AM
Eg253
Suspension & Brakes
30
Jun 24, 2006 05:10 AM
flip b18b
Jun 28, 2004 10:31 PM
Matt B
Apr 20, 2003 07:12 PM
