short shifter install problem
Old Sep 3, 2004 | 06:30 PM
Integrity 19's Avatar
Default short shifter install problem
First off, I have searched this topic many times but I could not find a solution to my problem.
Here is the dilemma: I was trying to install a B&M shifter and I got to the step where you have to take of the two 10MM bolts that hold the shifter in place but I was not able to get them off due to the little flat heads that hold the bolts in place. The exhaust does not drop down enough because it is welded in place. One of the bolts is also stripped so there is no way that thing is coming off. I cant seem to get a wrench on the flat heads to remove them, and even if I do, one is stripped beyond belief.
Has anyone ran into this predicament before? What should I do? Should i take a torch to the 2 bolts or should I try to chisel them off? Thanks.
Old Sep 3, 2004 | 07:14 PM
RAK's Avatar
RAK
Default Re: short shifter install problem (Integrity 19)
It sounds as though you are trying to change the shifter with it still under the car. You need to remove the entire rod that holds the shifter up, put it on the workbench, and deal with the situation. The bolts are designed to stay in place so you should be able to get a visegrip on the stripped nut and get it off like that.
Old Sep 3, 2004 | 08:11 PM
jdm_cars's Avatar
Easy solution..
Go find another helping hand.
Have one guy sit in the car and hold the flat bolts with a pair of pliers
While you go under the car and Loosen/Tighten the bolts.
Done this many times.
Old Sep 4, 2004 | 05:50 AM
Default Re: short shifter install problem (RAK)
I will try your suggestion today. Thanks for the advice.
Old Sep 4, 2004 | 09:31 AM
aeon's Avatar
go to team-integra.net and check out the article they have on installing a short shifter.
Old Sep 4, 2004 | 09:56 AM
Default Re: (aeon)
Finally, short shifter is installed but I could not figure out where the donut-shaped energy suspension bushing went. I installed the long one with the three holes but not the other one.
Thanks for the help.
Old Sep 4, 2004 | 11:00 AM
aeon's Avatar
Default Re: (Integrity 19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integrity 19 &raquo;</TD></TR><TR><TD CLASS="quote">Finally, short shifter is installed but I could not figure out where the donut-shaped energy suspension bushing went. I installed the long one with the three holes but not the other one.
Thanks for the help.</TD></TR></TABLE>
follow the shifter linkage all the way to the engine/tranny, there will be a 12mm bolt holdnig in on, take that off and pull off the linkage. try and push out the old bushing and then put the new bushing in. before putting it in, lube up everything, it'll help out a little when forcing the new bushing in.
Old Sep 5, 2004 | 05:03 PM
Default Re: (aeon)
I tried to install the donut shaped bushing but I think the one I have does not fit my car. The bushing is too small and it has a cut down the center which separates it into two pieces. I think this bushing is made for a CRX, not an Integra.
Any advice?
Old Sep 5, 2004 | 06:47 PM
aeon's Avatar
what gen integra do you have?? the stock bushing and the new bushing you got should look exactly the same. if it doesn't then i guess it is for another car.
Old Sep 5, 2004 | 08:21 PM
Toadfart's Avatar
Default Re: (aeon)
Do the front bushings really help? I have not installed the fronts yet.
Old Sep 6, 2004 | 07:04 AM
Default Re: (aeon)
I have a 1994 integra, gen 3.
The donut shaped bushing is smaller than the stock one where the 12mm bolt connects it near the tranny. I am assuming that it is the wrong application but the other bushing fits fine.
ej8ster96
Jan 4, 2011 03:31 PM
toshko321
Oct 18, 2009 03:15 PM
JerkzEm1
May 16, 2005 06:34 PM
phreaker
Nov 7, 2002 08:46 PM
araknis
Oct 25, 2002 10:30 PM
