bad vibration question
Old Sep 2, 2004 | 10:20 AM
peacexisxfree's Avatar
Default bad vibration question
i have a bad vibration in the right front, mainly in 2nd gear only. anything above 3rd and it seems to stop. the balance is fine, and the lugs are tight. anyone had this problem before? any suggestions as to what it could be? ive checked for loose parts, to no avail.
Old Sep 2, 2004 | 10:31 AM
Revolver's Avatar
Default Re: bad vibration question (peacexisxfree)
at what RPM's?
Old Sep 2, 2004 | 11:39 AM
matman4444's Avatar
have you done anything to your exhaust? i think on the cat if you dont use those spring bolts and you just use regular ones then it can make alot of vibration
Old Sep 2, 2004 | 12:20 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree &raquo;</TD></TR><TR><TD CLASS="quote">i have a bad vibration in the right front, mainly in 2nd gear only. anything above 3rd and it seems to stop. the balance is fine, and the lugs are tight. anyone had this problem before? any suggestions as to what it could be? ive checked for loose parts, to no avail.</TD></TR></TABLE>
Try accelerating in 2nd gear, and then take your foot off the gas pedal. If the vibration stops when the throttle is closed, then your problem is one of the inner CV joints. Time for a new axle.
Old Sep 2, 2004 | 12:26 PM
Default Re: bad vibration question (PatrickGSR94)
it wouldnt the cat, although that rattles at times. i posted something similar a while ago and said i thought it might be a cv joint but someone said id only feel that when turning. either way, patrick, i think youre right. it might just be that. good thing i planned on new axles anyway. ill try decelerating and see if the viration goes away. thanks for he help.
sPaRk'iT's Avatar
I would say axles too.
TurboTagTeam
Oct 18, 2004 09:01 AM
Aquafina
Jul 31, 2004 04:59 PM
stealthhatch
34
May 18, 2004 01:22 PM
rocket256
Mar 10, 2004 07:50 PM
onyx00
Jul 26, 2002 06:57 PM
