code 22 after vtec
Old Sep 3, 2004 | 11:56 AM
pbizzlegsr's Avatar
Default code 22 after vtec
well last night as i was in vtec through 1st and 2nd ..then after 3rd i slowed down..next thing you know check engine light comes on..i pull the code and its 22..which is the vtec switch one defected i believe..no its not the vafc vtm wire because i had that 6 months ago and it was resolved..now 6 months later it happens..i searched and i read it could be bc of low oil..but my oil is nice and high where it should be..so does that mean replace the switch?..and is the switch the green plug under the solenoid? thanks
Old Sep 3, 2004 | 01:14 PM
davejj40's Avatar
Default Re: code 22 after vtec (pbizzlegsr)
clean the solenoid screen? I threw a code 22 also, but Im assuming its cause I dont have the VTM wire connected, btw sorry for stealing your thread but did u tap into the ECU line or re route?
Old Sep 26, 2004 | 05:25 PM
pbizzlegsr's Avatar
Default Re: code 22 after vtec (davejj40)
anyone knows why after i reset ecu its been fine for 3 weeks now and now it has come back? how common is it that the pressure switch goes bad? it came back on last night as i was about to hit 5200 where vtec is set to engage at in 5th gear..and it pops on..
Old Oct 15, 2004 | 01:10 PM
brent_G's Avatar
mine does this as well. I dont know what the hell is up.
racereaper7
Aug 14, 2007 08:56 AM
silverboost
11
Jul 11, 2006 04:46 AM
Bump
Sep 28, 2005 04:12 PM
Mentat Ghola
May 15, 2003 10:15 PM
311
Oct 8, 2002 11:42 AM
