Want to rev higher
Old Aug 31, 2004 | 06:12 PM
DsBananas94LS's Avatar
Default Want to rev higher
Applied for school loan to get a vetc head in a month I want to know if I change the cams when I put the head in and put a typeR ecu will I redline higher and would it redline close to 9000 RPMs
Old Aug 31, 2004 | 06:15 PM
GeeReg's Avatar
Default Re: Want to rev higher (DsBananas94LS)
The Type-R rev limit is 8600. Unless you have something to remove it, that's what it will be...
Old Aug 31, 2004 | 06:19 PM
Default Re: Want to rev higher (GeeReg)
would 8000 RPMs be safe and reliable for the ls/vtec
Old Aug 31, 2004 | 06:22 PM
GeeReg's Avatar
I'm not really up on LS/VTEC's. If you do alot of searching you'll find pretty much anything you need to know about it.
Old Aug 31, 2004 | 06:35 PM
Weapon_R's Avatar
No it is not safe. The best thing is to keep a stock LS block at under 8000rpm's, unless you want to build it up.
Old Aug 31, 2004 | 07:04 PM
steven975's Avatar
Default Re: Want to rev higher (MickeyA)
he's right. it's not safe. It will "work fine" but that doesn't make it right.
The GSR block has numerous enhancements to run at 8000rpm over the LS block. I know the difference between 6800 and 8100 SOUNDS small, but in engineering terms, they are worlds apart. GSR blocks are stronger, have a full girdle, oil jets, and much better balance.
If the LS block was safe to 8000 we wouldn't have GSR blocks.
Old Aug 31, 2004 | 08:04 PM
Stripped Honda's Avatar
99-0104
Default Re: Want to rev higher (steven975)
last time i heard school loans were for school not cars... but go figure ...
Old Aug 31, 2004 | 08:07 PM
xiLLtegRax's Avatar
Default Re: Want to rev higher (Stripped Honda)
maybe i should check out my school loan
Old Sep 1, 2004 | 10:38 AM
danteisme's Avatar
Loved
Community Favorite
Default Re: Want to rev higher (xiLLtegRax)
im guilty of doin the same thing as well...
but on topic, if you want to do a ls/vtec without building the ls block...you may want to just stick with gsr cams/b16 cams depending on what head you have IMO
Old Sep 1, 2004 | 10:56 AM
b18punk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MickeyA &raquo;</TD></TR><TR><TD CLASS="quote">No it is not safe. The best thing is to keep a stock LS block at under 8000rpm's, unless you want to build it up.
the ls motor can rev up to 8k rpm's fine and with a little head work (valve springs and retainers) you can rev it up to 8500 rpm's
but the ls cannot rev over 8500 due to the floating rocker arm design. anything over 8500 rpm and the floating rocker arms will pop out, break, or cause valve float. doesn't matter what mods you do, those rocker arms will still be there.
Modified by b18punk at 9:05 PM 9/1/2004
Old Sep 1, 2004 | 11:21 AM
Code Blue's Avatar
Default Re: Want to rev higher (b18punk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18punk &raquo;</TD></TR><TR><TD CLASS="quote">
the stock ls motor can rev up to 8k rpm's fine and with a little head work (valve springs and retainers) you can rev it up to 8500 rpm's
huh, i guess honda made a error when they put the rev limit at 6800
Old Sep 1, 2004 | 04:02 PM
b18punk's Avatar
Default Re: Want to rev higher (Code Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue &raquo;</TD></TR><TR><TD CLASS="quote">
huh, i guess honda made a error when they put the rev limit at 6800</TD></TR></TABLE>
because it stops producing power after 6500. and of course, for reliability reasons...
thats why the rev limit is set at 6800
Old Sep 1, 2004 | 04:39 PM
whiteyGSR's Avatar
hmm i think you should just do a gsr engine swap
Old Sep 1, 2004 | 06:28 PM
b18c1acura's Avatar
what if he were to go with a set of aftermarket rocker arms, would that help out with his rev limit?
Old Sep 1, 2004 | 06:46 PM
JDMwhiteDC2's Avatar
Default Re: Want to rev higher (b18c1acura)
most rocker arms ive seen that are aftermarket are quite expensive...
qpzm12
May 24, 2011 11:54 PM
jdmdikk
Jul 10, 2008 06:00 AM
G2integra217
12
Jul 9, 2005 11:21 AM
AllMotorCrxRACECAR
Jun 22, 2005 02:30 PM
Cyphear
Sep 6, 2003 11:08 AM
