need help fixing abs light codes
Old Jan 9, 2005 | 04:50 PM
lvietlboyl's Avatar
Default need help fixing abs light codes *searched couldnt find answer*
i was installing my camber kit on and i accidently pulled down on the control arm too hard. i heard a something ripping out of its place. i checked it out and everything seems to be in place. i got abs codes:
13 - wheel senor (open/short to body ground/short to power) FL
*i was working on this side when i heard the sound*
54 - fail-safe relay
81 - central processing unti (CPU)
if anyone knows how to fix any of these problems please help me out. thanks.
Modified by lvietlboyl at 7:35 PM 1/9/2005
Old Jan 9, 2005 | 06:35 PM
lvietlboyl's Avatar
Default Re: need help fixing abs light codes *searched couldnt find answer* (lvietlboyl)
bump
Old Jan 10, 2005 | 03:58 AM
JimBlake's Avatar
First check out the wire from the wheel sensor. You probably pulled it apart somewhere. Follow the wire until you find the break, then fix it.
If you're lucky the other codes will go away too. But wait & see if that happens.
Old Jan 12, 2005 | 05:52 PM
mstyper's Avatar
I found this web page it might help??
http://www.troublecodes.net/acura/
Old Mar 10, 2005 | 10:11 AM
lvietlboyl's Avatar
Default Re: need help fixing abs light codes *searched couldnt find answer* (JimBlake)
i checked the sensor cable and there is no break. the light is really bugging me
shutupitsANDREW
Jan 6, 2005 03:58 PM
kmcmpb11
Oct 12, 2004 08:47 AM
BryanSprinkel
Apr 5, 2003 06:55 PM
Prelussion
Aug 5, 2001 11:10 AM
